Originally Posted by albertomc
Hey Monty,
I have that same head unit and had that same issue. Try updating firmware and software from phone and head unit as that helped me with the static calls. Hope that helps
I will take a look thank you.
Originally Posted by seLect
I have a Pioneer-z110bt head unit if you were interested in buying an used one? No issues with it - including Bluetooth connectivity. The only problem is that it does not tilt outward where you can insert CD's etc unless the shop installed it wrong.
I drive a '18 Limited now so I had the shop take out the old head unit before trading in the '04 with stock radio to get the maximum $ possible. I kept the Pioneer backup camera for the backup '07 Sport, though so it'd just be the head-unit by itself.
Happy to take pictures or address any of your questions if you're interested in it. It's just sitting collecting dust right now in my closet, lol.
I will look it up and let you know, right now gonna try the update and see if that helps. Thank you
Originally Posted by Bluesky 07
@ Monty87ls
, if you decide to go another direction, I highly recommend the Pioneer AVH-2550NEX. I installed it in January 2020 and it's been terrific.
I will check it out thank you!
Originally Posted by iowabadger
Ouch,, have one in the box ready to install in our '08. Samsung phone?
Yes Samsung Note 10plus. New issue now is it will connect but only for calls.
Originally Posted by JH225
Not happy with mine either. One half of the RCA outputs are DOA right out the box. Works fine I guess if you ONLY need CarPlay, but I need the head unit to do a bit more and it’s woefully failing to deliver.
Great.. I didn't even get to hooking up an amp yet that's gonna be a spring project I would be very ticked off if I get there and they don't work.
