Old 11-19-2020, 08:59 PM #1
joshik joshik is offline
joshik will become famous soon enough
Post Slider Install - Rougher Ride...?
Just installed White Knuckle Sliders yesterday. They look great and can't wait go get some use out of them.
Has anyone noticed that post slider install (weld or bolt) that their ride is rougher? Could it be that the frame is stiffer now? I seem to notice that when I am moving and turning, even SLIGHT turns/curves, I can feel the tire tread. My tires are old and wearing unevenly, but prior to the sliders, I never noticed any tire tread noise/bump. I can hear it and I can feel it in the floor boards. I can only tell when im turning/curve left. Turning right, maybe the passenger can feel it. Haven't tried that yet.
Time for some new tires!?!?!?!
Any thoughts?
2003 4Runner Limited 4wd V8. JBA UCA, Dobinsons MRA Front Coilovers, Dobinsons MRA Long Travel rear. Cooper AT3 XLT 285/70R17
91 Ext Cab 4x4 Yota, black with 4" front IFS trailmaster lift, 3" Downey rear springs, Downey Rubicon extended shackles, and 2" body lift. 35" BFG M/T w/ 4.56. Centerforce II clutch, Rancho 5000s all around and Rancho traction bar, K&N Air filter, Flowmaster, ARB Rear Diff Air Locker, Custom "Mad Eyes" light covers, Extended Diff Breathers, Hella Vision Plus Headlights. [SOLD]
joshik is offline   Reply With QuoteReply With Quote
Old 11-19-2020, 10:43 PM #2
montijo505's Avatar
montijo505's Avatar
Probably the slider passing on the vibes, since they span a large portion of the frame. I didn't notice anything with my sliders (same brand) but I had new tires when I installed them.
Sent from my SM-G986U using Tapatalk
Old 11-20-2020, 04:38 AM #3
I think I found some info.
Noise/vibration when turning left?
This is the EXACT Issue I'm having. It sounds like when ur tire rubs on the inner fender or mud flaps but I know it's not rubbing anywhere as it didn't rub before and I just got a BMC and mud flap delete.
The above thread the person had bolt on sliders like me (diff brand) . I'm guessing they have the same clearance issues as the white knuckles. That top front bolt is so tight up against the body that it is touching the body and any vibrations get transfered straight thru that bolt and into the body down by my feet.
I'm going to back out that bolt and nut and see if that changes anything!
Old 11-20-2020, 02:11 PM #4
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Think your on to it.
Kinda seems like the front mount, the part the U-bolt bolts to, rubbed.
Mine was hiting the bottom of the passenger side floor.
Little body lift helped mine. 1/2"
Seems like someone bent the floor up for clearance.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 02:44 PM #5
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
I think you hit the nail on the head. If a bolt is touching the body it will transmit vibration from the frame to the body. Kind of like why the exhaust is mounted on rubber hangers. (Sorta)
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 11-20-2020, 08:40 PM #6
montijo505's Avatar
montijo505's Avatar
I also had a body lift already installed so maybe why I didn't have the issue.
Old 11-20-2020, 08:58 PM #7
Yeh I'm pretty certain now too. I talked with white knuckle and they said that is an issue when you have worn body Mounts. I guess they think it's compressed and now lower than factory......
I checked and the front mount and its is definitely close and prob touches when flexing from turns and what nots. I loosened the Mounts and tried to force it down and give some space but couldn't get to really drop much. I put some wood shims between the body and the mount and it help dampen the rumbles but it is still present.
I don't want a body lift so I may look at pounding the body a little and/or grind off a little from the top of the mounting tab.
feel , post , slider , tire , turning
Slider install Spish 3rd gen T4Rs 31 04-06-2020 10:26 AM
Slider install trouble rihavens 5th gen T4Rs 6 04-29-2018 01:12 PM
Install Shrockworks Slider by Yourself jdkilroy 4th Gen T4Rs 9 11-04-2013 03:40 PM
Help! Slider install at a standstill mtbnole 5th gen T4Rs 10 05-07-2011 10:50 PM
Does 4runner ride rougher than GX470 fjc32 4th Gen T4Rs 8 10-25-2004 10:47 PM
