11-24-2020, 02:38 PM
#16
Cheap where? OEMs are 300 a pop. I have found aftermarket replacements for cheap but at this point I'm not even convinced they are bent. Might still crab a set and gusset them for good measure.
They are available for a very good price if you call them a "steering knuckle". The second someone calls the exact same part a "spindle", the price multiplies by 3.
NEW Front Driver Left Steering Knuckle Fit for Toyota 4Runner 43212-60200 USA | eBay
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
11-24-2020, 02:50 PM
#17
Real Name: Derek
Real Name: Derek
Nice.
These and a set of spindle gussets, little practice welding...
Even these used are not this cheap.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
11-25-2020, 03:19 AM
#19
Originally Posted by Drift Monkey
Have them gusseted before install if you never want this problem again lol
Sent from my SM-G986U using Tapatalk
11-25-2020, 02:58 PM
#20
That gusset design with the c-shaped fish piece looks very strong.
2005 Blue SR5 v8
11-25-2020, 03:12 PM
#21
I'm gonna probably do this anyway - but even at this point I'm not totally user it's a bent spindle - ala
@ Inv4drZm
2006 4Runner Sport Edition V8 4WD
11-25-2020, 04:44 PM
#22
Total Chaos, these allow you to retain your sway bar also, if that's something you care about.
11-25-2020, 05:28 PM
#23
I don't run the sways and still gonna get that version haha.
11-25-2020, 06:08 PM
#24
I'm fairly certain the cheaper Total Chaos gusset kit that doesn't incorporate the factory sway bar has been know to concentrate the stress in a certain area and crack the welds.
11-25-2020, 06:28 PM
#25
I've read the same. I'm gonna be messing with the Taco Tabs front bolt setting as soon as this weekend - it depends on if i get rained out on my wheeling/camping trip this weekend or not. Hopefully I'll be able to get the camber back in spec this way.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
