Old 11-24-2020, 07:30 AM #1
dvto2 dvto2 is offline
dvto2 is on a distinguished road
Stuck brake caliper...
2005 sport, v6. Passenger front caliper.
I got the outside caliper open fine but I can't seem to budge the inside caliper. I've been using 3" bessey c clamps on the wings of the brake pad and tried opening up the bleeder valve but it won't seem to budge. Suggestions please.
dvto2 is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 07:44 AM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
New calipers, once they seize up they usually can't be used any longer,
2004 Limited V8
Old 11-24-2020, 07:55 AM #3
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Get a rebuilt caliper off Amazon. I had a caliper that was frozen and it took the mechanic 2 hours to get it working and it froze again.
rebuilding has to be done by professionals like Amazon.com: MAYASAF 192712 192713 Front Disc Brake Caliper Left & Right Both Side Caliper w/Hardware for Toyota 2003-05 4Runner, 2001-07 Sequoia, 2000-06 Tundra [Casting 13WL]: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 12:12 PM #4
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
If you have the funds available right now, do the upgrade to 5th gen calipers. They still seize, but they are less seizure prone than the stock 4th gen ones.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 04:31 PM #5
Rannd's Avatar
Rannd Rannd is offline
Rannd is on a distinguished road
Rannd's Avatar
Not true. My 5th Gens sized faster than my 4th Gens. I'm back to 4th Gen calipers now.
2007 Toyota 4Runner Limited - My Build Thread
Rannd is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 05:38 PM #6
metramm metramm is offline
metramm will become famous soon enough
When my driver's side front froze, I bought a NAPA eclipse as the toyota dealer said that's what they were installing if it wasn't an OEM part.
Installed it and been working fine for 25k miles or so.
It was cheap, like 100 bucks and has a lifetime warranty, just keep the receipt.
Metramm
2006 4Runner Limited 4x4 v6
241,000 miles and counting!
metramm is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 01:31 AM #7
little_titan little_titan is offline
little_titan is on a distinguished road
I have been reading that as long as you flush your brake fluid every 2-3 years your calipers wont seize. Especially in the salt belt states...any truth to that fellas?
OP, time for a new caliper like the others said. I ran in to same problems.
little_titan is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 11:07 AM #8
Huh, what brand did you do? There is a whole thread on making the swap, so I did in the hopes it would be longer before seizing.
Then again, I live in the south so I probably get longer out of mine than most.
Old 11-25-2020, 11:44 AM #9
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
Is seizing mainly an issue with the front calipers, or are the rears just as susceptible?
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 08:31 AM #10
Get a new brake caliper off Amazon because yours will likely freeze up again after the installation and you'll have to do the job all over again.
I've had stuck caliper on front brakes. Front brakes have two sets of calipers.
Amazon.com: Callahan CCK02815 FRONT + REAR [4] Premium Grade Semi-Loaded OE Caliper Assembly Set Kit: Automotive
Access Denied
brake , budge , caliper , stuck , wings
Front Brake Pad Caliper Stuck HELP! briancl 5th gen T4Rs 17 08-31-2020 10:45 AM
4th Gen Front brake caliper rebuild for stuck piston Kmvreter Maintenance/Detailing 38 11-28-2019 10:14 AM
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
Quick question about stuck 2 of 4 pistons in brake caliper. kacper 4th Gen T4Rs 12 04-13-2015 10:19 PM
Brake Caliper Stuck? Kanger328 3rd gen T4Rs 4 10-07-2013 05:33 AM
