Old 11-24-2020, 01:59 PM #1
mightyduck mightyduck is offline
mightyduck is on a distinguished road
engine bay water damage
Hi all,
Yesterday I gave my engine bay a simple green rinse out. I tried to be pretty careful and fully removed the battery and put plastic bags over the black box right behind the battery (between the battery and the driver), as well as the unit with brake fluid on top of it (also inline with the battery, aforementioned black box, and driver). I tried to avoid getting much water under the engine cover and really just focused on the sides of the frame.
Well, went to start the car and it does start but it doesn't sound very healthy. At first when it starts it has a strong healthy roar but then immediatly dies off and sounds as if it's going to die. It manages to stay idling but feels a little frail.
Just wondering if there are any specific spots I should check to make sure there is no water build up. As I'm sure you can tell I don't know much about the mechanics of these things but I'm guessing this has something to do with the spark plugs or starter or something of that sort?
Any thoughts/suggestions would be appreciated.
2006 Sport v6 4x4 - 5100/5160 w/ FJ, K&N air filter, XenonDepot 4300k HID, Lamin-x yellow fogs, WeatherTech mats/rain guards, Yakima Whispbar, Plasti Dip badges/grill
mightyduck is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 02:18 PM #2
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Check the airfilter? maybe it got soaked somehow. I spray down my engine every once in a while without covering anything and it starts fine, just some squeaky belts for a while then it goes away.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 03:13 PM #3
Shit interesting thought...that would kinda make sense since it seems to roll over fine initially. Really hope I wasnt sucking water into the engine.
Old 11-24-2020, 03:37 PM #4
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
How many times have you started it since doing this? I could be completely wrong here, but I think there's a re-learning process. Last time (last week) I unhooked my batteries and put things back together it died right after starting. Started it back up and it was "weak" idling. Did that a time or two more after starting and then simply returned right to normal.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 04:04 PM #5
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I too occasionally spray dirt off my engines. Never had an issue.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 04:06 PM #6
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
Originally Posted by mightyduck View Post
Hi all,
It's possible you got water down in a spark plug tube and the coil's spark is shorting to the block bypassing a plug. Pull all coils and inspect for water.
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 04:18 PM #7
Piggity Piggity is offline
Piggity will become famous soon enough
What Pigeon said is likely the issue. I've had the same problem after replacing the battery and alternator on my 06'.
Past: 06' Limited 4WD V6 Nautical Blue Metallic
265/65R18 Cooper A/TW tires with TT - 2018 Forest River 201BHXL
Present: 08' Tundra Limited
33" Duratrac, spacer Lift with TT - 2022 Keystone 252RD
Piggity is offline   Reply With QuoteReply With Quote
Old 11-24-2020, 11:03 PM #8
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
This. Recently installed a new battery in mine and it ran like trash for the first 50 miles. Idling issues aside, any issues while driving?
eleven14 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 08:07 AM #9
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
This, computer needs to relearn it's settings. Go for a drive, solves itself.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 12:55 AM #10
Just wanted to follow up here with some feedback. The symptoms seemed to be getting slightly worse over the last few days; car would shake when I was idled at stoplights, very weak when it was starting up, and just didn't feel right. I called my local shop and asked briefly explained and asked if I could brining it in and they said they were very busy but suggested that in the meantime (if I felt comfortable) I should pull the coils and make sure there wasn't any water in the spark plugs.
So, I watched some videos and realized how straight forward this would be so I gave it a shot. First, checked the 3 coils on the passenger side one by one. Each one seemed dry and as far as I could tell they looked fine. I figured I would start the car before pulling the driver side ones just to make sure that if I ****ed something up I could at least isolate it easier. Well, it started perfectly fine with a strong growl and seemingly fixed the issue. I'm wondering if maybe there was some water in the seal that didn't really make it into the coil but maybe changed the humidity or pressure inside the coil? And then by pulling them out and putting them back in it effectively re-set the pressure/environment inside the spark plugs? No idea if thats remotely plausible but it feels like thats basically what happened.
Anyway, crisis averted -- thanks for the help.
Old 11-27-2020, 08:56 PM #11
Warwicke36's Avatar
Warwicke36's Avatar
Shoulda listened to me when I recommended it 😉.. Glad you got ir sorted.
2004 Sport 4.0
battery , black , driver , engine , water
ecu water damage hankd 4th Gen T4Rs 19 05-30-2022 03:33 PM
Possible Water Damage to Engine? jdm843 4th Gen T4Rs 4 10-07-2015 12:24 PM
Key Fob Water Damage Question GreyhoundGuy 4th Gen T4Rs 7 01-24-2014 09:06 AM
Interior Water Damage jaa 3rd gen T4Rs 10 10-06-2012 03:50 AM
Water Damage? bill99 Problems & Warranty Issues 5 10-28-2009 03:50 AM
