Old 11-25-2020, 11:31 AM #1
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Welding PCK
Hi. I'm looking to buy the eimkeith PCK. I'm a novice welder. How dangerous would it be if my booger harbor freight welds broke and my panhard bar became unattached? It seems like some straight forward welds. Nothing crazy.
I'll definitely do some practice welds welds before hand. (I haven't welded in over 4 years)
If this goes well maybe I can buy some weld on sliders
Thanks.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 12:00 PM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I would practice some butt welds in a similar position as it is on the truck (vertical). If you want to go a step further set up the practice so you are laying down on your back welding like you will be on the truck.
One of the hardest parts is seeing where you are going as you will be cramped under the truck, and the welds aren't a straight line.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 12:37 PM #3
phatcheeks's Avatar
phatcheeks's Avatar
Thanks. Once I tack it in, should I bolt the panhard in so it doesnt warp or you think it will be fine?
Old 11-25-2020, 12:38 PM #4
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Imagine driving 65 mph on the freeway and your pan hard gives up on you....
Take it off and have a shop do it for you. Save the cheap welder for non life critical welds like sliders and bumpers.
Now if you already have a badlands winch on your truck then you've already made your life choices.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 12:50 PM #5
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
I actually bolted it in to tack the bracket, so you know it will be in the correct spot. The remove the bar for full weld.
Pay attention to your heat and puddle and you should be good. Clean and chamfer everything up well. It's not a hard thing to weld but practice a little first and if you don't feel comfortable a shop can knock it out easy.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 12:55 PM #6
Inv4drZm's Avatar
Inv4drZm's Avatar
The panhard bar won't really keep it from warping. Just be sure to tack it in multiple spots, and jump around a little when welding it.
If you have a weld shop nearby you might get a quote from them, like mentioned above the panhard serves a pretty critical roll in keeping the rear axle centered. The PCK has plenty of weld area though, as long as you've practiced and like what you see it shouldn't be too hard to make it strong enough.
Old 11-25-2020, 12:57 PM #7
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
I'd NOT learn to weld on a project like this. Have a local buddy help you or pay to have this done. See if there's a local 4x4 4runner or landcruiser club member who can help you. Go to the clubhouse portion of IH8MUD.com and introduce yourself to the local folks. My local landcruiser club is a great resource for doing fab jobs like these. We have tubing bender owners, MIG & TIG welders and such who help out folks as needed.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 11-25-2020, 01:03 PM #8
phatcheeks's Avatar
phatcheeks's Avatar
Thanks all. I'll look around for quotes or someone who can help me. Being in the bay area im sure shops will charge a lot of this.
I will save the practicing for some sliders or something
Old 11-27-2020, 10:45 AM #9
Toyrundrive Toyrundrive is offline
Toyrundrive is on a distinguished road
I may be crazy but I consider sliders life saving devices...
Being in the bay you might be boned, take a trip south. I know shops in LA will have reasonable rates, I don't believe anything is reasonably priced within 50 miles of any bay area city.
Head to Oregon and find a fab shop in the country on your way and make an appointment a few days in advance. It's literally a 1 hour job in a driveway, likely quicker in an actual shop. You can handle a 4 inch lift without the correction for a very long time so don't worry too much about doing it immediately.
Toyrundrive is offline   Reply With QuoteReply With Quote
buy , crazy , hand , pck , welds
Welding advice Mark_BC 3rd gen T4Rs 3 07-05-2017 01:06 AM
Tips for welding? Mostly safety First time welding a truck frame shahsmerdis 3rd gen T4Rs 31 02-14-2017 11:38 AM
Any one willing to do some welding for beer? mwray8909 So Cal 1 10-01-2016 05:27 AM
Need welding in NYC Asaspades93 General Discussions 1 07-30-2014 08:47 AM
welding azshtr General Discussions 2 05-02-2012 08:00 PM
