Old 11-26-2020, 12:34 AM #1
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
How prevalent is the transfer case actuator seizing problems?
Hey everyone,
I have a 97 sr5 4wd with the mechanical J shifter and a newly picked up 08 v8 limit 4wd. I love the simplicity of the 3rd gen but the refined bits of the 4th gen. When I tested the 4th gen 4L, it works fine.
I am going to be selling one of these rigs and I wanted to ask how prevalent do these 4th gen transfer case actuators seize up? I don't want to let go of an extremely reliable 3rd gen just to step into a 4th gen where I can expect for some of these high dollar problems to occur.
Any thoughts are appreciated How prevalent is the transfer case actuator seizing problems? thank you!
Sent from my Mi MIX 2S using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 01:07 AM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Do a FJ tcase swap and don't worry about the actuators failing ever again.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 10:07 AM #3
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Originally Posted by TejasRunner01 View Post
Hey everyone,
Just make sure to use it regularly. I will put it in 4wd at least couple times a month and also use 4lo when reversing into my steep driveway sometimes. Maybe change out the tcase fluid with some new fluid.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 10:31 AM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Transfer Case Actuator
4x4 PSA: Use it or lose it monthly reminder
TC actuator maintenance?
DIY: Transfer Case Actuator Repair
Transfer Case Actuator Leak - Fix OPTIONS & Thoughts
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 07:16 PM #5
Since the actuators are currently working, should I now worry about it as long as I keep using them monthly?
Old 11-28-2020, 07:35 PM #6
bob3dsf's Avatar
bob3dsf bob3dsf is offline
Real Name: Bob
bob3dsf will become famous soon enough
bob3dsf's Avatar
Real Name: Bob
If it's working fine, just keep exercising it periodically. Now, that doesn't mean there might not be some other issue on the horizon, but that wouldn't be likely and something that anybody could possible face. When I first got my 08 back in 11, I noticed my low range didn't want to go into gear. Read up on it here on T4R and tried to shift it a couple times every day and hope that I caught it quick enough to avoid any serious problems. After a day or two, as I remember, it started working with no further problems. A nice thing about the 4th gens is the normally open center diff (don't even know how the 3rd gens are configured). The v8 is an AWD so you don't even have to worry about shifting from 2W to 4W (AWD, essentially, in the v6's), just work that low range and your center lock (on a straight road if dry).
2008 SR5 4WD
bob3dsf is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 10:45 PM #7
Thanks for the reply Bob. I will certainly do that. So far, loving the 4th gen!
3rd , 4th , 4wd , gen , prevalent
Transfer Case Actuator Coveman 4th Gen T4Rs 60 03-30-2022 11:31 AM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
Transfer case actuator Brian3676 4th Gen T4Rs 2 12-19-2015 12:30 PM
transfer case actuator Benji2169 General Discussions 1 05-30-2014 08:34 PM
Transfer Case Actuator 4RunnerV8 Maintenance/Detailing 2 09-15-2008 10:12 PM
