11-27-2020, 02:18 PM
Fumoto Drain Valve
I did my first oil change a couple of days ago and the mess was not pretty. I've used Fumoto drain valves on other vehicles before, but location of oil plug on this T4R is concerning, as it's pointed directly to the ground which provides little protection if an object were to hit that drain valve I'm referring to, which measures 1.25". What I found great about our T4R is the METAL splash shield as all other vehicles I've owned were made of hard plastic. So a metal splash shield is certainly more protective, but what if?
Just curious if someone has used those drain valves and what their take on them. Thx
11-27-2020, 02:43 PM
I've been running the F103-S, which has the short nipple. Easy enough to hook a hose on it but doesn't stick as far down as the regular N.
Just picked up an Oil Udder to avoid the mess of the oil filter as well.
You'll be golden with both of them.
2008 Nautical Blue GX470
Bilstein 6112/5160
11-27-2020, 05:10 PM
Real Name: Calvin
Real Name: Calvin
I have one on mine, but I also have RCI skids so I'm not too worried about it snagging anything.
2006 Sport Edition 4x4 V8
Bilstein 6112 w/ King 700# springs (5th clip), Toytec 2" springs in the rear w/ ICON 2.0,
CBI single hoop front bumper, Smittybilt 9500 XRC, RCI steel full skid package, 285/70r17 BFG KO2s on TRD Offroad wheels
11-27-2020, 06:51 PM
Also running one with steel skid plates. Easiest oil changes ever.
Sent from my SM-G986U using Tapatalk
11-28-2020, 12:20 AM
Real Name: Russell (OB #9908)
I’ve had one for years with no issues, including off the pavement. See my YT channel link below if you’re interested in where the Fumoto has been. They’re golden.
11-28-2020, 11:51 AM
I installed one of these a few oil changes ago. Great product, great functionality. I would highly recommend one.
11-28-2020, 12:09 PM
I got the f103s as well. It doesn't go past the stock skids, so you should be fine.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
11-28-2020, 12:18 PM
No experience with one on a 4runner, but I've run the F103S on our Sienna the last 15000 miles or so. With that and their hose kit, oil changes are almost too clean! I'd have to imagine on a V6 4Runner, a Fumoto + the top mounted filter would make changes stupid easy.
11-28-2020, 12:25 PM
Real Name: Joe
Real Name: Joe
If you end up getting one, order the F133 not the F103. The 103 is the old valve with a smaller outlet. F133 has a larger drain and so it only takes about 4 minutes to drain the oil, vs 15 with the old one.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
11-28-2020, 04:58 PM
That's reassuring. I just ordered on Fleabay, and yes F133S is the updated version.
11-28-2020, 06:51 PM
I've had one installed for 30k miles with stock skid plates. Mostly city driving with an occasional trip on a forest road. No problems.
'08 Silver SR5 V6 4x4: OEM+
11-28-2020, 06:57 PM
I have the V6, and for the toyota oil filters I have a socket for a 1/2 drive ratchet. No more struggling to get an oil wrench on the filter, its in a tight spot sometimes lol. Easy peasy.
11-29-2020, 12:11 PM
I run the 103N with an RCI skid. It’s just too easy! I recommend it.
11-29-2020, 02:52 PM
Super jealous of this setup vs. the stupid cartridge filter setup on the Sienna. Lol
11-29-2020, 03:16 PM
It is very convenient.
