Old 06-21-2017, 12:24 AM #1
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Electric motor sound from under dash - NOT BRAKE BOOSTER.
I'm hearing an odd noise under the drivers side dash in my 03 LTD V8. It is NOT the brake booster motor. This is something different.
To me it sounds like an old hard drive seeking files or maybe a remote control car steering left and right. The only thing I can think of is HVAC servos but I hear they make more of a clicking noise when they fail.
I've twiddled with all the hvac controls but nothing changes the noise. When the noise goes away I tried all the buttons again but it didn't make the same noise.
Anyone heard this before?
https://youtu.be/93HtE99T6B8
Give it a few seconds and you'll hear it clearly.
Montego Murph is offline   Reply With QuoteReply With Quote
Old 06-21-2017, 04:11 PM #2
RedRumt4r RedRumt4r is offline
RedRumt4r is on a distinguished road
i have the same problem . everything i read its the blend door actuator
RedRumt4r is offline   Reply With QuoteReply With Quote
Old 06-21-2017, 04:18 PM #3
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
From your vid, it sounds like mine which is caused by the Air Mix Control Servo Motor. A way to test it is to change your temperature setting from all the way up (hot) to all the way down (cold), the sound should go away as it re-positions. I believe there is only one for non-dual climate control like mine and 2, a right and a left if you have dual climate control. See here for more info:
Mission Impossible - Air Mix Servo
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 06-23-2017, 09:23 PM #4
tacoma747 tacoma747 is offline
tacoma747 is on a distinguished road
Mine does this, I hate the thought of how much fun it would be to change the blend door... Luckily it's my wife that drives it daily so I don't have to listen to it often.
tacoma747 is offline   Reply With QuoteReply With Quote
Old 06-25-2017, 02:48 AM #5
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
Hard to hear, but does it sound like this? https://www.youtube.com/watch?v=DbmpiqZnWzw
If so, apparently its a common problem with the toyotas.. IIRC, the pins in the servo in the AC control get weak over time, so after some aging, they begin to have weak contacts making this weird sound..
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
Old 11-16-2020, 10:33 PM #6
mwampler mwampler is offline
mwampler is on a distinguished road
I replaced mine a couple of weeks ago. It was the lower one which was the air mix servo. Kind of a pain in the butt but doable.
mwampler is offline   Reply With QuoteReply With Quote
Old 11-22-2020, 12:43 PM #7
ScSportsman ScSportsman is offline
ScSportsman is on a distinguished road
My grandma has an 03 Sienna that had the actuator for the blend door go bad and it sounded like a motor running constantly. I was able to turn her thermostat all the way down then reach underneath and help it "find" its spot.
ScSportsman is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 11:27 AM #8
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Red face
AC fan motor is failing/running
I don't hear much from your link
normal engine running noise
shut off the engine it will go away
Ha!
Captsolo is offline   Reply With QuoteReply With Quote
anyone have electric brake booster problems/failure? NJshadow93 4th Gen T4Rs 10 10-19-2020 09:05 PM
Electric Brake Booster or Master Cylinder going bad? judogti 4th Gen T4Rs 8 04-28-2017 05:07 AM
Electric brake booster jmauld 4th Gen T4Rs 8 06-30-2015 09:17 PM
Electric motor noise under dash when stopping utmba95 4th Gen T4Rs 4 05-27-2015 06:32 PM
Electric motor noise under dash/drivers side undercarriage WarEagleDoc 4th Gen T4Rs 8 09-15-2010 12:03 AM
