Old 04-30-2021, 03:01 PM #1
Urbanite Urbanite is offline
Urbanite is on a distinguished road
Choice of Gear Oil
I'm getting ready to change my rear differential oil and was wondering if this would work? If I buy 7 quarts, it's free shipping and would be enough for 2 oil changes.
85W90 Hypoid Gear Oil - Liqui Moly LM20010 | FCP Euro
Also, locally someone is selling Toyota factory's gear oil for a great price, but it's for an LSD and mine is not. Is it OK to use LSD gear oil in a non-LSD differential?
Urbanite is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 03:34 PM #2
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
The rear calls for straight SAE90 gear oil. Its kinda hard to find in stores so most people just use 75w90 which is the same for front diff and transfer case. Not sure about the 85w90 for the rear.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 03:53 PM #3
montijo505's Avatar
montijo505's Avatar
I use Mobil 1 75-90 in front and rear diffs. I buy it at Walmart they have the best price. You need I believe 5 quarts for front and rear. T case I run the Toyota stuff.
Maybe someone who has used the products you linked will come in.
Old 04-30-2021, 05:16 PM #4
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
The oil you are considering says for transmissions that require Gl-5. Doesn't mention differentials. I would stay away from for diffs.
LSD gear lube fine in non-LSD.
Old 04-30-2021, 05:41 PM #5
phatcheeks's Avatar
phatcheeks's Avatar
Interesting. My manual says 75w90 for the transfer case
Old 04-30-2021, 06:14 PM #6
montijo505's Avatar
montijo505's Avatar
Yeah, I’m just paranoid. Plenty of people run the Mobil 1 75-90 in all three (both diffs and tc) with no issues. I’m up at 165k so just weary of replacing it with something new.
That being said I’m a weirdo that runs all Toyota fluids for everything, except the diffs lol.
Old 04-30-2021, 06:39 PM #7
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I use this in both diffs and the tcase - Amazon.com: Red Line 57904 (75W90) Synthetic Gear Oil - 1 Quart: Automotive
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 07:02 PM #8
This is the right stuff for rear diff, cheap and could last for a long time (5 Gal). But never heard of this name:
GL-5 SAE 90 Heavy Duty Automotive Gear Oil - 5 Gallon Pail (18L - 4.75 GAL) - Walmart.com - Walmart.com
EDIT: I searched for manufacturer (SINOPEC) and it looks like this is a Chinese state owned company. Would you use a Chinese fluid? I know everything is now made in China, but with fluids I'm a lot more conservative.
Old 04-30-2021, 07:53 PM #9
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
I wouldn't use it, personally.
There's really no reason not to use the same 75w90 gear oil in the rear that you use in the front and tcase. Unless you get different gearing and/or a locker and the installer tells you to use something different that is specifically required by the gears/locker.
Old 04-30-2021, 09:27 PM #10
SA-Overland SA-Overland is offline
SA-Overland is on a distinguished road
Valvoline 75w-90 full synthetic. Never failed me!
SA-Overland is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 01:07 PM #11
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
Probably completely overkill but the rear diff is a weak point so why not,
I have been using Redline HD shockproof for the last 15k of offroading and road tripped miles with great results. Changed it recently and it came out looking as good as new.
Choice of Gear Oil-signal-2021-04-08-104928_001-jpg
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 05-02-2021, 01:57 PM #12
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
I used the amzoil version because you can get it in collapsible quart containers so I don't need a pump to put it in.
Edit: This was for my 5th gen, 75w 90.
Swipter is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:13 AM #13
FordF150 FordF150 is offline
Banned
Real Name: Tommy Bahamas
FordF150 is an unknown quantity at this point
Banned
I used Vavoline 75-90 non synthetic. I plan on doing it again at 70,000m miles as it's a simply job.
Synthetic is so overrated. Conventional nonsynthetic Valvoline was all the parts store had .
three quarts and you are done in 15 minutes.
FordF150 is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 11:31 AM #14
triethylborane triethylborane is offline
triethylborane will become famous soon enough
Back again?
triethylborane is offline   Reply With QuoteReply With Quote
Old 05-03-2021, 12:51 PM #15
leonp24 leonp24 is offline
leonp24 is on a distinguished road
CaptSolo or CaptF150? All you need to do is get some quality synthetic oil to stop all of your oil leaks. And some proper WS for your WS transmission.
leonp24 is offline   Reply With QuoteReply With Quote
differential , gear , great , lsd , oil
Review: East Coast Gear Supply Gear Swap comtn4x4 5th gen T4Rs 27 09-20-2021 07:57 PM
4runner Doesn't know it's in Gear, Gear Selector in Dash Not Lit, VSC goes off the_josh 4th Gen T4Rs 2 01-26-2021 01:35 AM
Nitro Gear 4.56 ReGear - Why the different Gear Oil??? 007Tacoma 5th gen T4Rs 10 01-19-2021 04:57 PM
Gear shifter really hard to move/shift into gear (auto trans) infamousRNR 3rd gen T4Rs 7 07-03-2018 03:42 PM
If you had a choice do it all over again - 1st or 2nd Gen jast513 Classic T4Rs 17 04-02-2007 03:31 PM
