Old 12-07-2020, 11:07 AM #1
Badmeat's Avatar
Badmeat Badmeat is offline
Badmeat is on a distinguished road
Badmeat's Avatar
Badmeat's 2003 V8 Limited Build - RSTRNR
After a couple months with no 4Runner (first time in over 5 years), I've finally landed on a 4th gen to pickup as a second vehicle. I sold my 2015 Pro and picked up a 2019 Tundra Pro for the increased towing capacity. The purpose of the 4Runner will be a second vehicle to keep miles off of the Tundra (currently pacing to do 20-25k/year) and also have something to do some light/medium off-roading. I'm only a couple hours from Red River Gorge so that's a plus.
The rig:
The 2003 is going to need some TLC. It has about 220k on the clock and the following issues will need addressed:
-Exhaust replaced/supported, as it's hanging down and there's no piping behind the muffler
-Cracked exhaust manifold. This seems to be common on the 4.7 and it's either a live-with-it situation or set aside a couple days to replace it.
-Seeping valve cover gaskets. I've been told this may be resolved with tightening the valve covers. If not, they will be replaced.
-Drivers window binds when door is shut below 1/2 way. This may be a tracking problem or some adjustment needs made.
-Rear bumper disconnected on drivers side where it meets the body. Passenger side scuffed.
Other than that, just some general cleaning and servicing of fluids will be done. I'll also scale the frame and coat it with wool wax, after the sliders are installed.
Plans for the rig:
-OME lift with 886 front springs and Toytec Superflex coils (will swap rear springs/shocks if I add a rear bumper in the future). From what I've read the 886 is recommended for the V8 model when running a winch/bumper
-Victory 4x4 Blitz front winch bumper
-8-10,000 lb winch (undecided, but considering the Engo SR10s [owned one in the past])
-285/70/17 A/T tires. I have been very happy with Terra Grapplers in the past but may try the new Toyo Open Country tires. I also understand that spacers or different wheels will likely be needed to fit these, as well as UCA's. The jury is still out on E-load tires, as I'm going to likely be driving this 10k+ miles/year and don't want something loud on-road or stupid heavy
-Sliders. A good friend of mine had an issue with his Jegs sliders for his 3rd gen and they send him another set. Basically, they were missing the mounting plates. They let him keep the first set so I'm getting some on the cheap. A mutual friend of ours welded them up and referred him to a local powdercoater that did them on the cheap.
I'll update with pics once the purchase is completed tomorrow.
Badmeat's 2003 V8 Limited Build - RSTRNR-0c66bd34-7f51-4fc0-b562-8adf0c956ae1-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-3c51e95d-e0d7-4888-b056-1d8ffe4adb31-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-62dedfad-3987-4da9-a207-9c2cd738de62-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-1f601c84-9d6b-44e7-a530-ef474e911f6c-jpg
2003 Ltd V8 - The RST RNR & 2019 Tundra TRD Pro
ALL SOLD:
2015 Inferno TRD Pro
2013 SR5-P
2001 SR5
Badmeat is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 01:21 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 will become famous soon enough
-Cracked manifold: Depending on the severity and your climate (rust) you can remove, weld together, and re-install to save money. I did that and it cost me a felpro gasket and about 6-8 hours. It's a tedious 1 man job but not overly technical.
-Valve Cover leaks: Be careful not to over torque those small bolts. You can do more damage than good. Best it to replace correctly the first time. Alternatively you could try high mileage oil which may help the seals swell back up better.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 12-11-2020, 11:59 PM #3
Badmeat's Avatar
Badmeat's Avatar
The valve cover gaskets have shrunk over time. Some of the bolts were literally finger tight. They’ll be replaced if leaking continues. I’ve embarked on the manifold replacement tonight. I have an OEM replacement lined up for $Free-fitty.
What I’ve determined after getting the top 4 out and the Y-pipe off.....rust sucks. It’s slow progress, and lots of heat and penetrating oil is needed. So far I’ve only snapped one exhaust bolt but was able to extract it. I’ll be tackling the remaining 4 manifold bolts on Sunday.
Also, I’ve added a photo to the OP
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-12-2020, 12:42 AM #4
Badmeat's Avatar
Badmeat's Avatar
I’ve had a lot going on this week. After picking up the 4Runner Monday, I dove right in. Rear diff fluid change, transfer case fluid change, greased the driveshaft zerk fittings, and front diff fluid to come soon (I had to cut the front skid off to access it, as it was bent near the front passenger mounting bolt). The one philosophy that I fortunately have taken to heart is heat, penetrating oil, and patience. I’ve only broken one bolt so far (aside from the two license plate bolts) and heat/PB blaster have been my two best friends.
Tonight a couple friends came over (one owns a 2001 4Runner lightly built, the other a 2008 Tacoma pretty heavily built) to assist with the exhaust manifold replacement. Although I was on the struggle bus on my back working on rusted exhaust bolts, one of my cohorts were able to get 4 of the manifold studs out (the nuts pulled the studs, as expected). Something else we decided to do was remove the strut assembly as I’m replacing them with an 887/5100 combo (not a lot of 4th gen data available but I’ll play test subject. Dobinsons makes a similar offering that’s what I’m looking for but this setup is on the cheap, used). The tophat had literally fused to the strut “bucket” and after 30+ minutes of persuasion, it finally separated. I would like everyone to note the red circle (attached). This is the area that I would recommend using a hardened chisel and hammer on. The one thing that I learned tonight is that it takes a lot of persuasion all around the tophat before you hit two taps on that area to break it loose. Please don’t ever hit that spot first or it may separate too easily, without enough struggle.
If the passenger side gives me the same trouble, I may lose sanity. Fortunately, I have the cheat code now.
At the end of the day, we had enough choice beverages to keep the mood relaxed and laid back tonight. There are 4 nuts/studs to get out and the manifold is free. I’ll update in a couple days with good news (hopefully).
Side note- I installed new garage lighting Wednesday which was a helpful addition to the project. I will again add that nearly 220k mile 2003 exhaust bolts earn a lot of four letter words when being “removed”.
Badmeat's 2003 V8 Limited Build - RSTRNR-3c7f2bdd-60ec-4af4-aaeb-adabf484530e-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-f86ee68a-cfcc-4a74-bfe7-0b18b9550f88-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-c7c57a85-dfd9-4ab0-b207-f833c1d71bb3-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-10cc2c04-abb0-41a9-bb20-6a0b3c64ba7e-jpg
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-12-2020, 01:23 PM #5
Roody Roody is offline
Real Name: Ross
Roody is on a distinguished road
Real Name: Ross
Looks exactly like mine! Looking forward to following along and seeing how our builds are similar/different.
2005 4R Limited Titanium Metallic - 4.7L V8, 270k miles - stock (for now)
2018 4R TRD Off Road Premium - Sold 7/2019
2005 4R - "The Stormtrooper" - Sold 6/2019
Roody is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 10:19 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss has a spectacular aura about rdruss has a spectacular aura about rdruss has a spectacular aura about
rdruss's Avatar
Real Name: Ron
I have an '03 Ltd. too, every project is a battle with rusted bolts, etc. Did my top hats a few months ago and they needed some persuasion like yours! Take a look at your frame below front passenger door. The a/c condensation tube exits the firewall in engine compartment on that side right above frame and on mine the condensate ran down the frame and stopped under door where it dripped on ground but also rusted sizeable hole in bottom of frame. relocate the drain with a elbow and hose and clamps to get condensate away from frame. Was a $1000 frame patch for me!
Old 12-13-2020, 10:21 PM #7
Badmeat's Avatar
Badmeat's Avatar
My frame will definitely be getting some reinforcement. It’s a little soft on that side.
Update:
Manifold has been removed with no broken bolts! Can anyone guess where it was leaking?
Also, both strut assemblies are out as well. I’ll be driving down to Louisville Friday to get the replacement manifold and my suspension should be in this week as well. More updates soon.
Badmeat's 2003 V8 Limited Build - RSTRNR-0503aee5-5fd0-44bc-b1d1-26ba8e21ac65-jpg
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-15-2020, 07:04 PM #8
Badmeat's Avatar
Badmeat's Avatar
Update:
I replaced the factory sub today. It has obviously seen better days (see attachment). The new one sounds good and should sound better once I get the headunit replaced and am able to tune the frequencies better and adjust the crossovers.
I was able to solve the airbag light issue. It appears that the drivers seat was replaced at some point and the old connector with cut wires was never removed and the harness plugged in (see pics). This was a nice ten minute fix that cost me free-fitty and now my dash is light-free.
Also, the suspension showed up. 5100s with OME 887 for the front, Toytec Superflex for the back. The fronts are used from a good friend with an 08 Taco. He now has a badass Fox setup with remote resi all around and had these in the garage. Now featuring new KYB top hats and bushings.
Next up is some frame patching to take place this weekend where there are some soft spots on the passenger side. The condensation drain tube for the a/c drips directly on the frame right at the rear of the front wheel well (as rdruss mentioned in an earlier post) and the engineer that designed that should be demoted. I’ve extended/re-routed it so that the frame should stop experiencing constant moisture.
Badmeat's 2003 V8 Limited Build - RSTRNR-8e752670-aa0b-4099-802f-99797bfd8a39-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-fd2a2542-8a86-426c-8883-71e408c99af1-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-7395178d-f4df-4db3-a717-ef1b514f5ff4-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-a496996c-194b-4a1c-909a-20c1b564189f-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-8ac97551-52d4-4206-bcc9-4b821bab3d68-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-3264d783-ff34-4afe-af83-5a520632e234-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-70b23da3-651d-4652-aa73-c5c8f19cee28-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-5228feed-3f3a-4340-a13f-3706da7cbf34-jpg
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-19-2020, 11:00 AM #9
Badmeat's Avatar
Badmeat's Avatar
Not a bad setup for sub-$1,000. I was able to scoop up some like new TRD OR wheels for $350 and some very lightly used Wildpeak MTs for $600 off of a Jeep Gladiator.
This weekend thereís going to be a lot going on. Iím hoping to get the replacement exhaust manifold and front suspension installed, as well as the passenger frame patched/reinforced.
Badmeat's 2003 V8 Limited Build - RSTRNR-cee3c331-1fb7-4a42-ac03-6d1a1c83cc06-jpg
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-19-2020, 11:43 AM #10
montijo505's Avatar
montijo505 montijo505 is online now
montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold montijo505 is a splendid one to behold
montijo505's Avatar
Damn, you really dove in head first! Subbed for updates.
Sent from my SM-G986U using Tapatalk
'08 4runner SR5 4x4 natural white
Toytec Ultimate Lift/ Toytec 1Ē Bodylift/ Stealth Custom Series Ray 10ís matte gunmetal 17x9 -38 offset/ Falken Wildpeak AT3W's 285/70/17/ K&N CAI/ Auxbeam LED headlights/ blacked out headlights/FlowMaster 50 Series/black MBRP tip routed to passenger side/Satoshi mod/ Coastal Offroad front bumper and skids
montijo505 is online now   Reply With QuoteReply With Quote
Old 12-19-2020, 12:31 PM #11
Badmeat's Avatar
Badmeat's Avatar
Full send. The quicker this is done, the quicker the miles I'm putting on my Tundra slow down.
I'm planning to go with another Kenwood Wireless Apple Carplay unit for this, as the DDX 8706S that I've had for the last 18 months has spoiled me. First, we need to sure up the frame and get this thing drive-able.
I also forgot to add that I ordered am Aisin timing belt/water pump kit from Rock Auto. Not a bad deal at $160.
The only maintenance items at that point left are an oil change and transmission fluid change (all diffs have had a fluid change and the drivetrain lubed up).
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-20-2020, 08:40 AM #12
Badmeat's Avatar
Badmeat's Avatar
I got the exhaust manifold in last night but there’s not much to see, so no photos. I’ll be installing the Y-pipe, and hooking up the o2 sensors so that I can switch directions that it’s facing, so that means at least the front suspension and wheels/tires will be done today in addition to the frame repair.
Pics to come later.
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-20-2020, 09:44 PM #13
Badmeat's Avatar
Badmeat's Avatar
Iím exhausted but hereís a quick photo dump.
Today the frame was patched. Installed was:
-Front/rear lift
-Exhaust to the secondary cat
- Replacement taillight & rear bumper (free)
-Passenger door card (better shape than mine, free)
-Wheels & tires
It doesnít seem like a lot when I type it out but when everything is rusty, it takes so much longer. Both rear shocks sheared off the studs on top. Iím pretty sure Iíll need a new propane torch when this project is over.
Badmeat's 2003 V8 Limited Build - RSTRNR-6e8541ee-9503-4cde-9760-d750bf724c64-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-a1f17261-f8da-4c6c-ab6a-e397f36ebc17-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-d3ff06b3-7024-4731-b4bc-838b991d56cf-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-d4a09555-50d0-449d-999d-70f3cbcb21aa-jpg  Badmeat's 2003 V8 Limited Build - RSTRNR-702128cf-d2fd-4bd8-8d8f-f2969988a22c-jpg
ALL SOLD:
2013 SR5-P
2001 SR5
Old 12-21-2020, 03:15 PM #14
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I too, have a '03 V8 LTD and if I didn't know better I would think I was looking at my frame repair when I look at your pictures, had same exact rust problem from the a/c condensate vent line.
What exhaust manifold did you get?
New wheels and tires look very good!
Old 12-21-2020, 03:35 PM #15
Badmeat's Avatar
Badmeat's Avatar
I went with a free-to-me OE manifold off of another 2003. I'll be bolting up the rest of the exhaust today to confirm it's leak-free. However, I have Y-pipe installed and am 99% confident there's no leaks, based on how it sounded yesterday.
ALL SOLD:
2013 SR5-P
2001 SR5
bumper , couple , rear , set , tires
2003 SR5 build mykdee 4th Gen T4Rs 11 02-20-2021 09:14 PM
Badmeatís 2015 Inferno TRD Pro Badmeat 5th gen T4Rs 40 04-16-2019 01:48 PM
James' 2003 Limited V8 Build James720 4th Gen T4Rs 7 09-14-2018 01:58 PM
Skulls 2003 Limited Build Skulls 4th Gen T4Rs 32 11-29-2017 05:11 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
