Old 12-09-2020, 12:21 AM #1
WRTR5's Avatar
WRTR5 WRTR5 is offline
WRTR5 is on a distinguished road
WRTR5's Avatar
Angry '05 Screech on Cold Start
Ok so I'm probably being a baby but this screech on cold start is concerning me. I'm guessing it has something to do with the power steering pump?
2005 4Runner Screech on Cold Start - YouTube
2005 Toyota 4Runner SR5 V6 2WD
2005 Toyota 4Runner SR5 V6 4WD SOLD
WRTR5 is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 01:43 PM #2
royal T4R royal T4R is offline
royal T4R will become famous soon enough royal T4R will become famous soon enough
V6 or V8
It sounds like an electric pump, not mechanical. My V8 also makes a noise similar to that just not as violent. I believe it has something to do with the brake booster.
royal T4R is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 08:04 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Originally Posted by royal T4R View Post
V6 or V8
I also think it's most likely the electric ABS/booster pump motor making the noise, if it is the motor it should also make the noise when you use the brakes several times, normal operation is the motor comes on when you turn on the ignition and also comes on after you depress the brake pedal approximately 3 to 4 times as the pressure drops, the motor normally runs about 10 to 15 seconds or so the motor should only make a slight buzzing noise but if the brushes are worn down it will be much more noisier like the noise you're is making.
You need to pinpoint where the noise is coming from, if in the area of the master cylinder, then I would check the motor.
2004 Limited V8
Old 12-09-2020, 09:27 PM #4
WRTR5's Avatar
WRTR5's Avatar
It only occurs on a cold start and doesn't happen anytime after that. Even if I rapidly tap the brakes it doesn't make the sound. Also, the engine has to be cold. If the temps outside are like 60 F it doesn't do it which is strange.
Old 12-09-2020, 09:28 PM #5
WRTR5's Avatar
WRTR5's Avatar
V6 or V8
Its a V6
Old 12-09-2020, 09:49 PM #6
Real Name: Skip
Real Name: Skip
You are still going to have to pinpoint where this sound is coming from before you can find what it is that's making the noise, from the sound I heard in your video I'm still thinking it's the electric ABS/booster motor, it could only be making the noise when cold and then heat buildup could possibly cause the noise to cease, pinpoint where it's coming from and then we can possibly determine what causing it.
2004 Limited V8
Old 12-09-2020, 11:58 PM #7
WRTR5's Avatar
WRTR5's Avatar
alright well I'll have to wait till the weather's cold enough then I'll try to pinpoint it. Thanks for the help!
cold , pump , screech , start , steering
22RE Cold Start - Delayed Start - Exhaustive Troubleshooting pinemind Classic T4Rs 17 09-18-2021 07:38 PM
Cold start/ hot start problem GASGTO73 Classic T4Rs 4 03-03-2010 03:30 PM
Why doesnt my 4runner start when its cold...it will start with some gas pedal 96boo2 3rd gen T4Rs 1 03-07-2007 10:56 PM
cold no-start T4RVt Classic T4Rs 0 02-28-2006 01:44 PM
95 4runner cold start NO START UrbanAssult Problems & Warranty Issues 0 02-06-2005 11:53 PM
