11-02-2021, 10:17 AM
#16
Originally Posted by kcdehart
She sat in the shop for a month, but the headgasket is DONE. Along with timing components, a valve adjustment, and a new oil pump. The end cost?? A lot. Significantly more than I posted earlier BUT it's starting up great now (no misfires, no water noise), I got a little over 18mpg on a highway trip yesterday (I was sitting at around 13-14 before), and the engine is *so* smooth. Not a single tick.
Here are some pics of the parts the shop gave me back. The timing bits weren't bad, but the oil pump *really* needed replacing. Check out that play at 200k miles (click the last image, it's a vid).
Well at least now you pretty much have a brand new engine. I wonder if that would of been a better option? just installing a newer motor or rebuilt one.
Glad you were able to get it fixed though.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
11-02-2021, 10:22 AM
#17
Real Name: Kevin
Real Name: Kevin
I considered it. With a new engine, though, I'd have still wanted to replace the headgasket, timing, and oil pump - just so I wouldn't have to do this job again in who knows how many miles. The parts cost of those was the majority of the extra I ended up spending since all the labor was basically being done anyways with the headgasket replacement.
At this point, I'm just planning to keep this thing for a *very* long time.
'04 4Runner - Build Thread | '05 CBR 600RR & 1000RR - The slow vehicles ;)
11-02-2021, 04:14 PM
#18
Unless you're throwing in a new motor I'm with you.. plenty of parts to replace anyhow before it goes back in so might as well work with what you have
11-02-2021, 04:27 PM
#19
Real Name: Kevin
Real Name: Kevin
For what it's worth, the shop told me the leakdown came back perfect on my heads. So unless something is screwy on the bottom end, this engine should be good to go for a long time.
12-21-2021, 10:31 AM
#20
Real Name: Kevin
Real Name: Kevin
Found out that the valve cover was leaking *bad* after getting it back from the shop. Took it back to em and they said it was warped/wanted me to pay for new OEM parts ($390). Bought one off of eBay for $50 and did the job myself. Found that the term 'warp' wasn't quite accurate...
Reached back out to them and ended up getting a nice refund to cover the parts cost and my time spent. Still frustrating, cuz it makes me question the rest of the work that they did...
12-21-2021, 11:05 AM
#21
clearly they followed the torque sequence and definitely did not exceed the Ugga Dugga's specified in the manual.. but on a serious note, stuff like that pisses me off coming from a "shop". This is the sort of thing you expect to do yourself with minimal knowledge of how this should be done but anybody that charges money for repair services should know exactly how to avoid this. Or at least be stand-up about it and say "we messed up" instead of saying it was warped lol.
12-21-2021, 11:10 AM
#22
Real Name: Kevin
Real Name: Kevin
I actually think it might've happened when they were prying the valve cover off. He'd told me that they really had to pry at it, and you can see a little marring on the bolt hole in one of those pics. That honestly bothers me more, cuz then they'd have known they were putting on a bad cover, rather than just over torqueing it on final assembly.
12-27-2021, 01:30 AM
#23
Real Name: Kevin
Real Name: Kevin
01-10-2022, 10:31 AM
#24
Real Name: Kevin
Real Name: Kevin
02-01-2022, 06:33 PM
#25
Did you have to change the upper control arms?
02-07-2022, 10:07 AM
#26
Real Name: Kevin
Real Name: Kevin
Yeah, after being lifted for 5k miles or so, I found that my OEM upper control arms were *dead*. They'd worn notches into the balljoint carriers from being extended to their limits so often. I went to SPC UCAs.
03-18-2023, 01:10 PM
#27
Real Name: Kevin
Real Name: Kevin
My most recent addition
TrueNorth Fab front bumper that my buddy welded together. I then filled most seams with body filler to try to prevent rusting, and painted it with black appliance paint. Unfortunately we made the mistake of not test-fitting before doing final welds, so the wings aren't the same height - which will bug me for eternity. But oh well. I'm happy with it overall, and it should do its job just fine.
I've also swapped out my crappy LED pods for Lasfit flood ditch lights, and with the new bumper replaced the OEM fog lights with Lasfit fogs. *Very* happy with these! The fogs have a great cutoff and put out a loooot of light.
I also have an Ascend Overland rear bumper sitting in the house, but as the 4Runner is my daily till I get my Rolla GR, it's on hold. I'd rather not cut into the rear frame of my only vehicle
03-20-2023, 05:18 PM
#28
Truck looks great!
Can't wait to see the rear bumper... If I didn't put the effort into my swingouts, I'd definitely be wanting one.
2007 SR5 4WD Nautical Blue -- Build Thread
03-20-2023, 07:01 PM
#29
Real Name: Kevin
Real Name: Kevin
Originally Posted by gfxcruncher
Truck looks great!
Yeah, I'm super excited for it! It'll be nice to upgrade from the hitch carrier I'm currently running
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
