Old 05-29-2009, 08:03 AM #1
bpearson bpearson is offline
bpearson is an unknown quantity at this point
Key FOB Programming
Hello all
I purchased a 2006 4Runner Ltd a few days ago from Carmax and my baby has only 1 key fob. I still have the key fob from my dearly departed 2000 4Runner (may she rest in peace).
Is it possible to re-program the key fob to work with my new 4runner?
If possible does this have to be done at a toyota dealership? I appreciate any insight that you all may provide!
BTW I am new to this forum, so forgive me if this has been posted.
2006 V6 Limited
2000 V6 Limited
bpearson is offline   Reply With QuoteReply With Quote
Old 05-29-2009, 12:50 PM #2
T4RsRGR8's Avatar
T4RsRGR8 T4RsRGR8 is offline
T4RsRGR8 is on a distinguished road
T4RsRGR8's Avatar
This is really wierd, but I also traded in my 2000 ltd for a 2006 ltd., about a year ago. You didn't happen to go from black (2000) to white (2006).
Anyway, back to the subject at hand. My truck only came with one keyless remote and I too had to get a new remote and key. I bought a remote similar to the one in the link below. I paid $15 for mine on ebay in april of 2008. It works great, have not had any problems with it. The only problem was dishing out the $70 to the dealership to program the new key I bought. The remote that is in the link that I attached also comes with the programming instructions. Make sure that the FCC ID# and the IC# on the back of your remote match the numbers on the auction your looking at.
http://cgi.ebay.com/ebaymotors/2005-...1%7C240%3A1318
According to all the listings on ebay, I don't think that it is possible to program your 2000 remote. Most auctions I have seen do not include a large spread of years. Do your research, but I don't think it is possible.
Jay
2012 Limited Magnetic Gray Metallic 4x4 w/ Black Leather
T4RsRGR8 is offline   Reply With QuoteReply With Quote
Old 05-29-2009, 06:58 PM #3
Yes it is weird. My last 4Runner was silver and my current 4Runner is meterorite metallic. I can tell you that the 06 rides 100% better than the 00.
Thanks for the information, I will purchase another remote and have the dealer program it for me.
2006 V6 Limited
2000 V6 Limited
Old 05-29-2009, 06:58 PM #4
Thanks for the information, I will start bidding on a remote and have Toyota program it for me.
2006 V6 Limited
2000 V6 Limited
Old 05-29-2009, 09:37 PM #5
T4RsRGR8's Avatar
T4RsRGR8's Avatar
When you get the keyless remote, programming instructions should come with it. You program your remote to operate your locks, windows etc....
You will only need to include the dealer if you need to buy a new key, they have to program the key to work for your vehicle. I think it has to do with the chip needed to start the vehicle, something to do with the anit-theft feature.
Hope this helps.
Jay
Old 05-29-2009, 09:47 PM #6
jetboy1975's Avatar
jetboy1975 jetboy1975 is offline
jetboy1975 is on a distinguished road
jetboy1975's Avatar
Don't take it to the stealership to program. It is very easy to do it yourself. If you buy a fob on ebay it should come with instructions. If not I will post them below.
Programming for a 2003 to 2005 Toyota 4 Runner
When
Remote transmitter added or replaced.
System malfunction.
How
Driver's door open, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
Switch ignition ON and OFF once to program a remote transmitter code whilst
retaining the original codes or twice to program a remote transmitter code
whilst erasing the original codes. Three times to check how many remote
transmitters are currently registered or five times to erase all registered codes.
Remove key from ignition switch:
System should now lock and unlock vehicle once, twice or five times
depending which mode has been selected. One to four times, slowly, to
indicate number of remote transmitters registered.
Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds -
Within 3 seconds:
Press LOCK button.
System should now lock and unlock vehicle once to confirm registration,
twice to indicate registration has failed.
Within 40 seconds:
Repeat button procedure to program remaining remote transmitters.
NOTE: To exit programming mode: Open driver's door.
NOTE: A maximum of 4 remote transmitters can be programmed.
It may take a few tries and the timing must be very accurate to work but with a little patience it is easy.
'04 V8 T4R Limited Pacific Blue Metallic
Xreas removed, front FJ springs, Bilsteins all around, Toytec 1/2" spacer, Spidertrax, BFG AT 265/70/17, Curt 13445 hitch
jetboy1975 is offline   Reply With QuoteReply With Quote
Old 05-31-2009, 08:48 PM #7
MikesToy MikesToy is offline
Banned
MikesToy is on a distinguished road
Banned
bpearson,
I have an extra key FOB laying around. You got pm.
MikesToy is offline   Reply With QuoteReply With Quote
Old 06-01-2009, 09:22 AM #8
Originally posted by MikesToy
bpearson,
Great! Let me know how much you want for it, and I will send payment!
2006 V6 Limited
2000 V6 Limited
Old 06-09-2014, 11:12 PM #9
sr3tlaw sr3tlaw is offline
sr3tlaw is on a distinguished road
Exclamation 06-07 Programming
Here is the procedure that Worked for my 2007 Limited 4WD V8
Credit to "Count_Olaf" for the post over on yotatech forums
Hey all, i was gonna drop this in a new thread. i bought a replacement key fob off ebay and all the instructions i found here on yotatech didn't work for me. so the ebay seller sent me instructions on how to get it done and it was significantly different than what i found on here. Just wanted to get these instructions out there to help poor slobs like me. and when you program it , dont think about this too long, you have to scoot through the sequence at a pretty good pace.
1. Driver's door open, key removed from ignition switch.
Within 5 seconds:
2. Insert and remove the key from the ignition switch twice.
Within 40 seconds:
3.Close and open driver's door twice.
Within 40 seconds:
4.Close and open driver's door twice.
5. Insert the key into the ignition switch and close the driver's door.
6. Switch ignition ON and OFF once to program a remote transmitter code while retaining the original codes or twice to program a remote transmitter code whilst erasing the original codes. Three times to check how many remote transmitters are currently registered or five times to erase all registered codes.
7.Remove key from ignition switch:
Within 40 seconds:
8.Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds
Within 3 seconds:
9.Press LOCK button.
Within 40 seconds:
10.Repeat button procedure to program remaining remote transmitters.
SIDE NOTE: To exit programming mode: Open driver's door.
SIDE NOTE: A maximum of 4 remote transmitters can be programmed.
Hope this helps someone.
2007 LIMITED 4WD V8
Salsa Red Pearl
Husky Liners|Full Time 115v|Full Time 12v|Full Interior VLED|Independed Fog Light Mod|Dual Battery Optima Yellow/Yellow|Partial VLED Exterior|ICON Stage I|Moog Upper & Lower Ball Joints|DRL Mod|ProClip/Wilson Booster Custom Phone Mount|Bluesea Fuse Block|Speedohealer|Weathertech Bumpstop|Skids
sr3tlaw is offline   Reply With QuoteReply With Quote
Old 09-02-2014, 02:42 PM #10
joyntman joyntman is offline
joyntman is on a distinguished road
Keyless remote programming
Worked perfectly for my 07. Thanks!
joyntman is offline   Reply With QuoteReply With Quote
Old 09-08-2014, 05:09 PM #11
braddas_runner's Avatar
braddas_runner braddas_runner is offline
braddas_runner is on a distinguished road
Worked fine for my 2004 Sport Edition.
2004 4Runner Sport Edition 4WD - Bone Stock....For Now!
braddas_runner is offline   Reply With QuoteReply With Quote
Old 07-07-2015, 09:16 AM #12
dpark419's Avatar
dpark419 dpark419 is offline
Real Name: Dan
dpark419 is on a distinguished road
dpark419's Avatar
Real Name: Dan
These are the instructions that worked for me (2008 Sport Edition)
After having failed multiple attempts at programming my keyless remote with the wrong directions this one worked like a charm (2008 Sport Edition). THANK YOU
dpark419 is offline   Reply With QuoteReply With Quote
Old 07-14-2015, 05:10 PM #13
BOSMECH's Avatar
BOSMECH BOSMECH is offline
Location: Stockbridge GA. ( formerly Kent WA. ) & ( formerly Grafton MA. )
BOSMECH is on a distinguished road
BOSMECH's Avatar
Just got my 2 new Fobs in the mail and new keys.
Programed the Fobs in minutes and now need to get keys cut and program them.
I got them off ebay 2 Fobs and 2 master keys 33 dollars.
2003 SR5 V6 4WD Stock (totaled)
2005 Sport Edition SR5 V6 4WD
BOSMECH is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 11:48 AM #14
2geauxin 2geauxin is offline
2geauxin is on a distinguished road
Will not go in programming mode for keyless
I still cant get into programming mode 2000 4runner. I look like a retard when trying this 1000 times? All videos ive watched show the lock indicater on side of door/orange tab, 2000 do not have this. Is there a hard reset on receiver?
2geauxin is offline   Reply With QuoteReply With Quote
Old 01-15-2017, 12:17 PM #15
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Not sure what procedure you have tried but this is what I found for programming a 2000 4 Runner key fob...which is slightly different than what is posted for 2003 to 2005 4 Runners
Programming Instructions for keyless entry remote?
" Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door. "
