aftermarket camera?
if the rca cable have a wire built in, wire that up to either the acc or remote wire, you must undo the wire at the rear by camera, but if that wire provide both power and reverse trigger, just cap the wire off. also make sure you have good ground.
this way youll be able to use the camera as rear view too, use a separate wire to trigger the radio, on the driver side the reverse wire is red yellow, run a wire back to radio reverse trigger input.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
