Old 12-17-2020, 04:21 PM #16
MikeinNH67's Avatar
MikeinNH67's Avatar
So I dropped the seat as low as it would go I think. I measured from the center seat seam to the flat part of the ceiling, tape measure at a slight angle as I have a sunroof. It measures at 34". I have a 30" inseam and like the seat somewhat forward so take that into consideration. It would probably be better to measure from the floor at a set distance back as the way I measured is easily off a bit.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
Old 12-17-2020, 04:27 PM #17
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
6'3 210 here and long arms/torso/short legs. 36x32 pants. XS underwear.
my head is about 1" from the roof. enough to make me wonder if id survive a rollover.
im comfortable to drive with the seat all the way lowered, and slightly reclined (my arms > 6'3" span might help with this)
hinmo24t is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 07:52 PM #18
theoutbackdream's Avatar
theoutbackdream theoutbackdream is offline
Real Name: Matt
theoutbackdream has a spectacular aura about theoutbackdream has a spectacular aura about
Real Name: Matt
Originally Posted by MrSeth View Post
I ran some generic racing seats for awhile, welded to my OEM bases. They worked very well! Just decided to go back to more of a stock look after a while.
and then 2001 Lexus RX300 seats (I think). These were too puffy, made my nogin hit the roof while wheeling.
Originally Posted by JH225 View Post
I’m definitely considering keeping stock sliders like you did so I have some height adjustability. Looks like they worked well!
What did you do in terms of the airbag system? Did you put a resistor in place or did you just let it be? I’ve found conflicting info on if the airbag system gets disabled if one component (I.e. seat) is removed.
Sorry to bump this thread, but I was wondering if you guys were able to keep your airbag system enabled while having an aftermarket seat? I've been thinking about swapping one in, if I can find more info on this
2007 Limited V6 4WD Build Thread
Find me on Instagram @t4r_explorer
theoutbackdream is offline   Reply With QuoteReply With Quote
Old 07-23-2022, 11:27 PM #19
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
No worries about bumping, its the top google thread when researching other seats. I saw a resto-modded land cruiser that used BMW 5 series seats and looked awesome, but as the dude above asked, would the airbag work like the stock 4runner seat does? Its a daily driver, I'd like to keep the side pillow if I get t-boned.
Flybynight is offline   Reply With QuoteReply With Quote
Old 01-19-2023, 06:28 PM #20
Earnin’Turns Earnin’Turns is offline
Earnin’Turns is on a distinguished road
Just wondering if anyone found a way to increase legroom and headroom in their 4th gen runner?
A little tired of driving with my head cocked to the side and never being able to straighten my legs ��
Earnin’Turns is offline   Reply With QuoteReply With Quote
Old 08-06-2023, 07:09 AM #21
toddtt19 toddtt19 is offline
toddtt19 is on a distinguished road
Originally Posted by Billynath1988 View Post
These are on the wish list, I have read great things about this is a solution.
Front Seat Jackers - 4Runners, GX and FJs
– Desert Does It
I also looked into seat replacement and any option seemed extremely expensive. I did replace the seat foam myself and that seemed to be worlds better than the original worn down the foam. I have also seen a few posts along the way of swapped seats from a volvo, but it looks very involved.
How did you replace your seat foam? Mine is worn out on the drivers seat. Thanks.
toddtt19 is offline   Reply With QuoteReply With Quote
Old 08-08-2023, 09:05 AM #22
Billynath1988's Avatar
Billynath1988 Billynath1988 is offline
Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about Billynath1988 has a spectacular aura about
HOW TO: Replace Drivers seat bottom Foam- PIC HEAVY
2005 4Runner SE V8
http://www.toyota-4runner.org/4th-ge...-v8-build.html
Billynath1988 is offline   Reply With QuoteReply With Quote
Old 08-13-2023, 10:47 PM #23
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by gaber6 View Post
I'm similar size but more legs and arms. I feel like the seat bottom only supports half my thigh and on long trips it's not the best. Oddly enough, when I had the car packed tight for a cross country move, sitting close and upright was more comfortable long term and I had to get used to the "normal" position after I had room behind the seat.
Lol I did the same. So packed that it felt dangerous but I drove cross country no problem. It felt odd going back to a lounging feel. For sure I have no support from mid thigh.
gaber6 is offline   Reply With QuoteReply With Quote
Old 08-13-2023, 10:51 PM #24
Funny I'm 6'2" and had more room in my Audi TT driver seat.
gen , i’m , making , seat , work
Extending Driver's Seat Back For Tall Driver jtroop 3rd gen T4Rs 28 03-08-2021 09:03 PM
Driver Lean Spacer Alternatives? FamousAv8er 5th gen T4Rs 13 07-24-2018 06:54 PM
Wanted: 4th Gen Seat Foam for Driver Side Seat luke87gt For Sale: T4R Items 5 10-14-2015 05:17 PM
Driver Side Seat Foam Worn (under seat cover) luke87gt 4th Gen T4Rs 3 09-24-2015 10:50 AM
