Old 12-14-2020, 03:41 PM #1
theliman theliman is offline
theliman is on a distinguished road
sunroof leaking up front but front drains not clogged
Hi guys-
I park my car on a slight downhill slope. Often when it rains a decent amount, I will have water leak through between the small strip of headliner and the front of the sunglasses holder. Initially it was one of my front drains being plugged. I would blast it with air and pour water down and see that it would clear up.
This morning it was raining and I briefly opened my sunroof to look at the space where it would seem water would collect - where the drains are - there was no water collection. However, soon after driving (usually after a sharp turn) water came down.
Any ideas for where this could be coming from? Could an area I can't see be going to the front drains and they keep getting clogged? (I could try trimmer string) Or is there another area that water could be collecting? I know there are back drains, but if the failed would the water spillover so far toward the front (and bypass the front drains)?
Thanks!
2008 SE V6 4x4, Bilstein 5100's (1.75 in front), FJ springs, Cornfed 1" rear spacer, SCS Stealth 6, Toyo OC AT2 265/70/17, HID 4300k, Plasti-Dip front grill, Flowmaster 50 SUV
theliman is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 04:45 PM #2
JH225 JH225 is offline
JH225 is on a distinguished road
My experience with sunroofs on other cars is there’s a drip train all the way around, so I’m willing to bet there’s some water collecting in the rear area of the sunroof.
Let’s assume that you definitely have the front drains cleared and they stay cleared.
If the rear lines get clogged, you might have buildup of water in the rear are of the sun roof. Then during a turn that whole mass of water is moving at once. It’s not exactly “bypassing” the front drains, but it’s too much to drain at once. Kinda like dumping a 5 gallon bucket in the bath tub: it won’t drain immediately.
I wish I had more to offer. Whether it’s leaks or mechanism problems, dealing with sunroofs in general is sucky work. Best of luck!
JH225 is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 10:00 PM #3
thanks much - i'll dig a little deeper, including checking the rear drains once i figure out how
Old 12-15-2020, 10:30 AM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Sunroof leak = Drains clogged. Help pleaee
Moonroof Drain Locations (Underside)
4th gen sunroof rear drain exit location - Toyota 4Runner Forum - Largest 4Runner Forum
Clear Hose where Jack is Located.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
area , drains , front , sunroof , water
Sunroof leak = Drains clogged. Help pleaee Reh0055 4th Gen T4Rs 15 02-22-2023 08:03 PM
Leaking Sunroof Tip For Clearing Clogged Drain Holes bernardmwrangle 5th gen T4Rs 9 06-26-2019 01:32 PM
Sunroof drains clogged, sunroof doesn't work. Silicone? thezentree 3rd gen T4Rs 8 06-09-2017 10:31 PM
Fixing Leak - roof rack rail leaking, also with pics of rear sunroof drains. [pics] bener 3rd gen T4Rs 2 10-17-2014 02:53 PM
New member- leaking moonroof, drains not clogged d_benet 3rd gen T4Rs 1 02-23-2011 05:34 AM
