Old 12-18-2020, 06:13 PM #16
TheThreeFs TheThreeFs is offline
TheThreeFs is on a distinguished road
Originally Posted by 81runner View Post
For future reference, look for OEM axle-popper forks...life savers... everything else is just the hard way to do it.
Amazon.com: OEM TOOLS 27305 Axle Popper Kit, Fork & Shim Tool, Remove Most Vehicles’ Half-Shaft Drive Axles, Fix Damaged CV Joints: Automotive
I should have bought these before I attempted to get the axles out. The pry bars just didn’t work.
TheThreeFs is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 06:15 PM #17
I didn't see any trac or brake lights lit, so I figured it didn't have anything to do with abs. I don't believe the abs has anything to do with the engagement of the actuator. I have read about several stuck actuators, not had to change one out yet
It’s a pretty tight spot. I might have to take off a bunch to get to the actuator. What a pain. Was hoping someone has removed/replaced it.
Old 01-07-2021, 04:12 PM #18
Does anyone know what position the actuator on the front differential should be in when in 2wd?
Old 01-25-2021, 09:44 PM #19
So I did some research about the front differential and the ADD actuator. I figured that it’s possible that it could be stuck in between locking the front axles and letting them spin freely so I pulled the ADD actuator out of the front differential and checked that. The ADD actuator was all the way to the right which from my research means that it was fully disengaged. The lights on my dash are still flashing and I’m at a loss as to what to do now. The CV axles are doing well in there. I do remember though that when I took the driver side off, put the new axle in and then took the passenger side off and put the new one in. Then when I went to add differential fluid I pulled the driver side wheel off and found the axle driver side axle not all of the way in so I pushed it back in. Could that have done something? I’m at a loss of what to do now.
Btw, I’ve never touched anything on the transfer case and according to my cheapo code reader my car is not throwing a code
Old 01-27-2021, 05:03 PM #20
Anyone?
axles , car , flashing , lights , loss
Tapping into dashboard lights for toggle switch lights? Dom8706 3rd gen T4Rs 15 08-25-2020 12:43 PM
Dashboard lights going out!!! Fontino New Members 2 07-25-2012 09:30 AM
Dashboard Lights theaveragejoe 4th Gen T4Rs 1 12-14-2010 02:27 PM
Various Dashboard lights flashing rustyrazor Classic T4Rs 0 08-10-2009 08:52 AM
Dashboard Lights Spokaneman 3rd gen T4Rs 1 06-19-2008 11:27 PM
