Old 12-19-2020, 08:00 PM #16
Dan6789 Dan6789 is offline
Dan6789 is on a distinguished road
Originally Posted by xtremewlr View Post
It doesn't. Still works the same. Completely different system, unrelated to 2wd or 4wd.
Sorry, i quoted the wrong post. It was meant to quote the guy with the V8 who commented on 2WD mode with the FJ xfer case. How does vsc and traction control react doing rwd burnouts?
Dan6789 is offline   Reply With QuoteReply With Quote
Old 12-19-2020, 10:52 PM #17
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
It doesn't work because VSC and TRAC still work. Unless you disable VSC, you aren't doing burnouts. There are plenty of threads on how to do that.
I can disable VSC in mine and break the rear end loose in the dirt without problems or interference from TRAC. TRAC still works but is only really effective at slow tire speeds. I have not tried doing a burnout on pavement.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 11:35 AM #18
Ok, Good to know. Burnouts was a bit of an exaggeration, I don't think any of us would be doing smoke shows Cletus style. I am more interested what would happen in limited traction slower speed situations. Light snow in the suburbs going around corners, or wet grass up hill. I know on some vehicles if traction is lost the computer takes over and ends up locking up the brakes or pulling so much power that you can't even get the vehicle to turn a tire let alone move forward.
So the answer is if you want to use RWD do the VSC off mod and the computer wont go nuts and take over on limited traction terrain? Same thing if you want to do some donuts or slide a bit sideways for some fun?
Old 12-20-2020, 12:54 PM #19
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Yeah, pretty much.
With VSC off, TRAC still works and does not, by any means, interfere too much. If you get into a situation in 2WD or 4WD, it actually works really well as long as you don't apply too much throttle. It's helped me out of several situations that would otherwise have left me stuck due to a lack of a rear locker. Yet I can still have fun and do donuts if I'm in the mood.
Old 12-21-2020, 10:24 PM #20
BMoreRunner00 BMoreRunner00 is offline
BMoreRunner00 is on a distinguished road
Originally Posted by Runner-Wannabe View Post
Hey guys, I’m fact finding on 4th gens. I originally wanted a 3rd gen. but I’m trying to stretch my budget out to a 4th gen.
The question I have is what is the longevity of the V8 transfer cases vs the v6 models? (V8 is full time 4x4, v6 is not)
I’ll really only be able to afford something 250 mile+ range, so I’m worried that the V8 transfer case will be as tired as the trans. Could be a rebuild cost I can’t really afford to gamble on
My '04 V8 had its transfer case reaplaced under warranty at around 15k miles. It has 176k on it now and still works great.
One thing to keep in mine and this is really just my opinion - I wouldn't buy a 4th gen V6 model unless it was an '06 model or newer due to the common head gasket failures. They may have been fixed in '05 but im not sure.
BMoreRunner00 is offline   Reply With QuoteReply With Quote
Old 02-03-2025, 03:13 AM #21
Riley M. Riley M. is offline
Riley M. is on a distinguished road
Transfer case blew up after a bad u-joint was neglected
Hi guys, my transfer case on a 2005 v8 sr5 4wd 4runner blew up on me last month due to a badly neglected u-joint. I was wondering if any other kind of transfer cases would fit since any 05 v8 transfer cases for 4wd cost an arm and a leg even in the used market.
Riley M. is offline   Reply With QuoteReply With Quote
Old 03-14-2025, 03:21 PM #22
RBLACAUSA's Avatar
RBLACAUSA RBLACAUSA is offline
RBLACAUSA is on a distinguished road
RBLACAUSA's Avatar
Do you know what type of neglect the u-joints had, to cause a failure? Not routinely greased? Not routinely re-tightened to their torque specs??
'04 4Runner 4X4 SE V8
'06 4Runner 4X2 SE V8
'06 LX470
RBLACAUSA is offline   Reply With QuoteReply With Quote
Old 03-14-2025, 07:27 PM #23
4evagen4x4runner 4evagen4x4runner is offline
4evagen4x4runner is on a distinguished road
im new to the forum and dont know how to navigte....but i have a quick question will the v-6 tcase fit the v8 2003 4runner? both transmissions are electronic servo motor controlled and look to be the same. let me know please.
4evagen4x4runner is offline   Reply With QuoteReply With Quote
afford , case , gen , i’m , transfer
v8 transfer case swap to 6cyl transfer case? V8RUNN 4th Gen T4Rs 23 09-11-2020 01:40 AM
FS 3rd Gen '01-'02 Transfer Case Actuator $50 + Transfer Part Out, Idaho Falls, ID BanditJunior For Sale: T4R Items 1 05-01-2019 01:57 PM
RCI Transfer Case Skid doesn't have Transfer Case Drain Hole boyfester RCI Metalworks 1 01-09-2018 08:35 PM
WTB: 4th gen V6 transfer case shift motor/transfer case drewskie88 Want to Buy/Trade 0 01-11-2016 12:41 PM
Advance Adapters 50-5705 Transfer Case Adapter 700R-4 To A Toyota Transfer Case 21 To NMRunner Classifieds - buy & sell (no commercial ads please) 0 08-18-2010 11:42 PM
