Old 12-18-2020, 04:01 PM #1
MantanaB6's Avatar
MantanaB6 MantanaB6 is offline
MantanaB6 is on a distinguished road
MantanaB6's Avatar
Aftermarket Head Unit w/ Factory Backup Camera
Is this possible???
I'm looking to add a carplay enabled headunit to my 2008 limited, and have found that the factory backup camera won't work "plug & play" with most aftermarket headunits due to a difference in voltage (6V for factory vs 12v for most aftermarket/modern camera's I believe)
I have done some digging and it doesn't seem that there is much info on a solid solution; maybe I just haven't searched well enough. Has anybody developed a tried and true solution for this? I am willing to get creative and am comfortable soldering if need be.
2008 Limited V8 - Natural White - Nav
Bilstein 5100/4600+RAS - Cooper AT3 4S 265/65-18
My build thread
MantanaB6 is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 05:57 PM #2
JH225 JH225 is offline
JH225 is on a distinguished road
If you’ve got schematics of the factory camera wiring it should be possible! If voltage is truly the only issue, that can be fixed by a voltage step down board. Could probably find one on Amazon or Parts Express. 12V in and 6V out style.
JH225 is offline   Reply With QuoteReply With Quote
Old 12-18-2020, 06:25 PM #3
MantanaB6's Avatar
MantanaB6's Avatar
Thanks for the response! I'm not sure if voltage is the only issue; maybe I'll just pull the trigger on the head unit and step down converter and figure it out once I'm in there...
My build thread
Old 12-18-2020, 07:46 PM #4
Syr4RinNC's Avatar
Syr4RinNC's Avatar
Its possible - I just bought a new unit from Crutchfield and they have some wiring adaptors and guides for 4r with factory cameras.
Ill see if i can find it
____
So they list this one Reverse Camera Harness - PAC
I know for me the adaptors came at a significant discount buying the headunit through crutchfield. The harness there is listed for 2012-2013 4runners, but it came as an optional part listed in my instructions for 4r with back up cameras
Old 12-19-2020, 02:44 AM #5
MantanaB6's Avatar
MantanaB6's Avatar
____
Awesome, thanks! For some reason Crutchfield doesn’t offer that as an option for me, but I can just add it separately. What year is your 4Runner? I know there was some difference between pre- and post- ‘06 model years for the camera. Guessing post- would be most similar to the 5th gen...
My build thread
Old 12-19-2020, 09:19 AM #6
Syr4RinNC's Avatar
Syr4RinNC's Avatar
They’re kinda like a small business - I’d call or email them and see what they say
Old 12-21-2020, 03:12 PM #7
AceSpades AceSpades is offline
AceSpades is on a distinguished road
No need for any step down board, you just need 2 resistors and make yourself a voltage divider circuit... I did the same on my Ford Explorer years ago because i would get a loud thud sound when power on the stereo, i found that the oem amp needed only 5V and my aftermarket radio provided 12V, so i made a voltage divider to get 6V
Here is the circuit, really simple. Substitute camera for my oem amp in my drawing
AceSpades is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 07:02 PM #8
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm not seeing a drawing, is anyone else seeing a drawing?
2004 Limited V8
Old 12-28-2020, 01:03 PM #9
MantanaB6's Avatar
MantanaB6's Avatar
Nope, also not seeing drawing.
My build thread
Old 12-28-2020, 01:06 PM #10
MantanaB6's Avatar
MantanaB6's Avatar
Any concerns or issues with the heat generated by the resistors tucked back behind the headunit? Or did you mount the divider circuit somewhere else?
My build thread
Old 12-28-2020, 04:06 PM #11
It won’t be pulling much current at all, so heat is a pretty minor issue.
Resistors are definitely a viable option. I suggested a voltage step down board because they’re cheap and ready to go, not much thought involved.
aftermarket , backup , camera , factory , solution;
sr5 factory rear view camera with aftermarket head unit rnb754 5th gen T4Rs 22 12-23-2021 10:17 PM
How-to: Integrate factory backup camera into aftermarket head unit - 2018 OR Premium askdrtodd 5th gen T4Rs 1 04-08-2020 11:54 PM
New head unit and backup camera 5th Gen clemson4runner 5th gen T4Rs 3 03-30-2018 03:45 PM
Help picking new head unit and backup camera Jester4kicks Engines / Suspension / Wheels / Tires / Audio / Accessories 7 01-11-2016 12:00 AM
Fact Backup Camera on an aftermarket unit? Duc Hunter Engines / Suspension / Wheels / Tires / Audio / Accessories 12 04-06-2011 12:19 AM
