Old 12-20-2020, 04:17 PM #1
sel1005 sel1005 is offline
sel1005 is an unknown quantity at this point
2004 Limited Air Flow Control stuck
Hi, my 2004 Limited circulation control has stopped working, will only blow straight out no matter what circulation button you push. Defroster, floor, etc all light up but air flow is unchanged, always straight out at you. Had the compressor replaced a couple of years ago, everything is cold or hot depending on air temp setting but flow switch has me confused on what it could be.
Thoughts? Thanks
sel1005 is offline   Reply With QuoteReply With Quote
Old 12-20-2020, 04:56 PM #2
Real Name: Skip
Real Name: Skip
Thoughts? Thanks
You need to replace the HVAC "mode" actuator, on SR5 and Sport models there are 3 actuators "mode", "blend" and "recirculate", on Limiteds since it has the "Dual" system there are 4....one extra "blend" actuator for the driver's side.
Here are some search results for the HVAC mode actuator, but there are also results for the other actuators mixed in.
https://www.toyota-4runner.org/gsear...%3D3581861&ss=
Edit: The search results above has more then just the AC actuators, the following results has more results on the AC actuators.
2004 Limited V8
Old 12-20-2020, 06:32 PM #3
thanks for the info
Old 12-20-2020, 06:34 PM #4
sorry, forgot to ask, any idea what these may cost? with the truck being 17 yrs old its in great shape but can't afford to spend thousands on it either
Old 12-20-2020, 07:53 PM #5
Real Name: Skip
Real Name: Skip
If you're capable of replacing it yourself....about $130+/- for the actuator/part, but if you have to pay to have it replaced the labor can be several hundred dollars more.
2004 Limited V8
Old 12-20-2020, 08:38 PM #6
thank you
air , control , flow , limited , straight
2010 air flow level control issue? Majindan 5th gen T4Rs 0 08-04-2019 07:18 AM
2004 - New Radio, Stuck in 4H savesheep 4th Gen T4Rs 8 10-14-2017 06:41 PM
2004 limited cruise control fuse tk1979 4th Gen T4Rs 2 04-07-2011 08:43 AM
