12-23-2020, 11:38 PM
The disconnects make a lot of noise when disconnected. Be prepared.
2005 4R V8 4x
12-24-2020, 12:12 AM
Im using 2nd gen rears. No complaints here. No front sway bar
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
12-24-2020, 12:38 AM
Real Name: Devan
Real Name: Devan
The heim joint from the previous version gave me (and many others) loads of problems so I'm glad to see they were ditched, but the price definitely needs to come down still - especially for what they are.
12-24-2020, 01:39 AM
I made a set years ago from a diy thread somewhere on the forum. Budget friendly and no issues. I'll post a photo tomorrow.
Edit : these ones
http://www.toyota120.com/forum/showthread.php?t=24984
Sent from my SM-G986U using Tapatalk
12-24-2020, 09:18 AM
Real Name: Elliott
Real Name: Elliott
Originally Posted by montijo505
I have the same setup for the rear, love it. Hoping to grab a set of discos for the front in the next week or so
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
12-24-2020, 09:23 AM
Real Name: Elliott
Real Name: Elliott
What kind of issues did you have?
12-24-2020, 01:48 PM
Real Name: Devan
Real Name: Devan
whooole lot of clunking+popping over even the smallest bumps in the road, heim joint got nearly frozen after like a month, rust (zinc coating started wearing off quickly), the cherry on top was shearing off a bolt from the heim joint after driving down a basic logging trail
12-26-2020, 07:03 PM
Rear sway bars are totally useless with stiffer rear springs. I'm not even sure why people leave them installed. Just installing the heavier rear lift spring makes the truck sway less by a huge amount. These end links seem like inventions looking for a problem that doesn't exist.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
12-27-2020, 10:45 AM
Interesting. I didn't know people had so much trouble with the heim bolts.
The hard part is I haven't found many other options, and those I have found were expensive enough the cost was a wash. Agree on the cost feeling high... But custom hardware is never cheap.
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
12-27-2020, 10:46 AM
That's what I had heard. Figured metal in metal sliding will always be noisy...
12-27-2020, 10:50 AM
Huh, those are budget friendly, though not adjustable. I'm tempted to go adjustable in case I go long travel at some point in the future... Though that is a ways away if ever.
12-27-2020, 11:05 AM
You getting Mstudts disconnects? Or fabbing your own? I've considered making my own but the parts are about 150 on Mcmaster Carr...
12-27-2020, 01:56 PM
It's not the metal sliding. It's the clunking when the suspension reaches the end of the disconnects range of motion and stops the suspension travel. I am always afraid of it breaking when I wheel.
2005 4R V8 4x
12-27-2020, 07:36 PM
Huh, thats not encouraging. Do you feel like it buys you much of anything? Or is it minimal improvement sort of situation?
I'm actually thinking of building my own at the moment... The FJ people seem to like them a lot.
