Old 12-23-2020, 03:23 PM #1
Quiero Quiero is offline
Quiero is on a distinguished road
'07 with Billstein 5100s. Not sure where to go from here (lift)
I have an '07 that I decided to keep after a brief love affair with a 5th gen.
It has Billstein 5100s on their second to highest setting (front). Rear has 5100s also with a 1" spacer lift.
I currently have 31.5" A/Ts on it that rub.
I'd like to fit 33's. Can I keep the 5100s and add taller springs front and rear to do this? I wasnt sure if that would overextend the shock.
Quiero is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 06:09 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I bought the Toytec/Bilstein 5100 lift kit for my 2004 4Runner, so I have a 3” lift in the front and 2” in the rear. I never had just the shocks. I also have a Toytec 1” body lift. I am able to run 33” tires without any rubbing (Toyo Open Country AT2 255/80r17 on stock 5th gen 17x7.5” rims). I did have to do some minor cutting/trimming, but no BMC (yet). I also have 1.25” wheel spacers. With the Toytec front springs, the front shocks are at the lowest setting.
The 5100s are designed for lifted applications, so you shouldn’t have an issue with overextending the shocks. The 4600s are designed for stock height.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 06:42 PM #3
mkscrewy mkscrewy is offline
mkscrewy is on a distinguished road
yes, but you will put the springs at the 0 setting.
mkscrewy is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 01:07 PM #4
I'm good with some trimming and I plan on going with an aftermarket wheel/offset.
Is it possible to run 33's without a body lift or wheel spacers?
Looking at 3" Toytec front springs (w/ .5" spacer), 2" toytec superflex rears, and SPC UCAs now.
Old 12-24-2020, 04:22 PM #5
originalg00kster's Avatar
originalg00kster originalg00kster is offline
originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough originalg00kster is a jewel in the rough
You should be able to adjust the SPC uca so that you won't rub or hit body mount. But if you go off roading, I bet it'll hit.
07 SR5 4x4
originalg00kster is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 06:39 PM #6
Thank you. If I do the body lift will wheel spacers still be required or will the correct offset aftermarket wheel be enough?
I have my eye on these in 16x8 MK6 Off Road Rims by Level 8
Old 12-26-2020, 03:16 PM #7
Badmeat's Avatar
Badmeat Badmeat is offline
Badmeat is on a distinguished road
Badmeat's Avatar
I have OME 887 front springs and Toytec Superflex rear springs on 5100s. Stock UCAs (alignment went fine), and 5th gen TRD OR wheels on 285/70/17 tires. Nothing rubs and the UCAs clear fine through the full suspension travel. Any offset between zero and +15 should be fine (my wheels are +15). Front fender liners needed a little massaging with a heatgun and the factory XREA lines removed (doing that anyway with new suspension).
Pics and more details in my build thread in my signature.
2003 Ltd V8 - The RST RNR & 2019 Tundra TRD Pro
ALL SOLD:
2015 Inferno TRD Pro
2013 SR5-P
2001 SR5
Badmeat is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 05:26 PM #8
flipflopnfly's Avatar
flipflopnfly flipflopnfly is offline
flipflopnfly is on a distinguished road
If you do all that then get a better shock setup than 5100's. 5100's are a tiny shock, 46mm vs 65mm with Toytec Boss. Get the stronger shock, buy once cry once.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
flipflopnfly is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 11:21 PM #9
Trekburt Trekburt is offline
Trekburt is on a distinguished road
I think buying a coilover shock might be best (I'm wishing I had after awhile), but I have the same setup as you and just put on 33" tires. I kept my 5100 shocks but added the 3" Toytec spring, and put my 5100s on the third notch. Admittedly, it isn't as cushy as the bottom notch on the shock, but it's still comfortable, and looks great. I had to body chop and trim the wheel well, but I have no spacers and no body lift.
Sent from my Pixel 3 XL using Tapatalk
Trekburt is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 09:24 PM #10
Sunk cost fallacy but I have less than 5k miles on the 5100s =|. I'll run them for a year a few years, and will probably wear them out quickly with the way I've been wheeling lately.
Thank you for all of the replies!
Old 01-10-2021, 11:24 PM #11
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Keep in mind that .5" spacer will give you closer to an inch of lift in the front. So you'll be at 4" if the springs are rated a 3".
702tripgen is offline   Reply With QuoteReply With Quote
5100s , billstein , front , lift , rear
Billstein 6112s and Icon UCAs up front, 5100s and Icon 2-inch springs in the back. Nose Up trd6209 5th gen T4Rs 19 10-12-2019 10:19 AM
FJ Springs with Billstein 5100s. Data? simple 4th Gen T4Rs 9 12-20-2017 08:48 PM
Will 861s & Billstein 5100s work together? HammerHead 3rd gen T4Rs 5 04-08-2015 11:56 PM
billstein 5100s front/OME n86c rear thaemcee2 3rd gen T4Rs 6 01-31-2015 12:55 PM
My experience and tips to install front Billstein 5100s tony_4r 4th Gen T4Rs 8 10-30-2013 12:03 AM
