Old 01-04-2021, 05:13 AM #16
L8Shift's Avatar
L8Shift L8Shift is offline
L8Shift will become famous soon enough
L8Shift's Avatar
Originally Posted by oldboy View Post
Wow! Would you mind sharing the details of how that TPMS data gets to the radio? What specific hardware, besides the radio and crutchfield harnesses, is required? Does it need a specific TPMS make/model or standard tunable non-OEM TPMSs work?
Thanks in advance for your consideration!
Lou
The idatalink Maestro is the interface I used.
iDatalink Maestro RR Interface Module Connect a new stereo and retain the steering wheel audio controls and factory amps in select 2006-up vehicles at Crutchfield
I am installing the "Camera Source" camera for an OEM look. Backup Camera for 03-15 Toyota 4Runner
This was my second install with this type of audio hw, the first being in my Tacoma.
2006 T4R Limited V8 4WD, 150k, Toytec Bilstein, SPC UCAs, StopTech/Centric/Akebono Brakes, Methods/Ridge Grappler 285/70-17, Gibson exh., RCI Skid....
2007 T4R Sport V8 4WD, 145K, Pioneer NEX
1997 FZJ80 OME 2.5", Kumho AT51s, Slee Step Sliders
2006 Tacoma Pre-Runner Dble Cab Trd#2 Sport
L8Shift is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 10:40 AM #17
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina is on a distinguished road
Lou
Best buy says that the Pioneer DMH-2660NEX does not fit 4th gen runners. Did you have any installation hassles?
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 11:37 AM #18
blkexp98 blkexp98 is offline
blkexp98 is on a distinguished road
To add to the above post... did you buy a certain tmps sensor or do they all typically work since its a certain frequency. Having the exact pressure is nice too.
Sent from my SM-G975U using Tapatalk
2007 Limited 4Runner
4x4 V8
blkexp98 is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 01:17 PM #19
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
On the fence about replacing 2 bad sensors or just deleting the whole system with a simple scotchlock splice as seen on Youtube.
Strange thing is both sensors took a crap on a trip up the local mountain to around 8000' elevation. Not sure what the correlation would be between driving into a colder environment at a higher altitude and then the sensors going?
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:37 PM #20
oldboy's Avatar
oldboy oldboy is offline
Real Name: Lou
oldboy is on a distinguished road
oldboy's Avatar
Real Name: Lou
Thanks a bunch for the response! Unfortunately, I have an 04 which is not compatible... shucks... Lou
04 Limited, gray one
oldboy is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 02:53 PM #21
L8Shift's Avatar
L8Shift's Avatar
The psi/temp info comes from the OBD2 port (from the sensor).
The idatalink Maestro has a cable to the OBD2 port (and to the head unit).
I use Toyota /Denso sensors. Other manufacturer sensors that function with the OEM system would work.
Old 01-07-2021, 07:01 PM #22
L8Shift's Avatar
L8Shift's Avatar
When I initiated my research, Crutchfield listed the 2660NEX as "Not fitting" the 2007 T4R. I did more digging and found out it does fit, and with no issues.
The Metra 95-8202 Dash Kit Item #120958202 is what is depicted in the pic.
change , good , tire , tpms , years
5 TPMS sensors? Sky 5th gen T4Rs 15 12-17-2019 08:49 PM
TPMS Sensors? phillyd2 5th gen T4Rs 41 05-11-2018 11:22 PM
TPMS sensors powerone1 4th Gen T4Rs 7 04-27-2012 08:45 PM
TPMS Sensors Geosh 4th Gen T4Rs 0 02-23-2012 12:33 PM
Tpms sensors Lakland5 For Sale: Suspension/Wheels/Tires 2 02-05-2012 11:02 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
