Old 12-28-2020, 03:36 PM #1
Flybynight's Avatar
Flybynight Flybynight is offline
Flybynight is on a distinguished road
Flybynight's Avatar
What front springs for Bilstein 5100's?
My rig is a 2006 and has front spring sag, should I just get new replacement springs or is there another set-up that works better with these struts? I also ordered the 5100's for the rear and am leaving it stock height, really just want the front brought up level.
Flybynight is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 04:17 PM #2
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Will depend on if you want to add weight like bumper/winch. If not, just replace with Moogs that are rated for your vehicle and use the 3rd notch (should be around 2" of lift) and call it good. If you want to use less of the preload on the 5100 you could probably just order the v8 spring set (if you have a v6) and get some extra lift and stiffness that way.
702tripgen is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 04:41 PM #3
Flybynight's Avatar
Flybynight's Avatar
Yes its a V8 limited, no bumpers or anything will be added. I've located Moogs replacements for the front. Just go with those?
Old 12-28-2020, 04:53 PM #4
If you are getting the 5100's for the front then that's what I would do. You are getting refreshed (new) springs and then having the ability to set the height you desire with the clip position.
Please add the part number for the Moogs if you don't mind, I'm going through the same process as you right now. Thanks!
(don't quote me on the 3rd notch, I need to verify that, that is just what came to mind)
Old 12-28-2020, 05:47 PM #5
Flybynight's Avatar
Flybynight's Avatar
Moog 81088
Notches go from stock to 2.5, with these springs 2" should be perfect, stock saggers it would likely be 2.5 for compensation
Old 12-28-2020, 07:04 PM #6
Moog 81088
Awesome
Old 12-28-2020, 11:35 PM #7
newton22 newton22 is offline
newton22 will become famous soon enough
I recommend leaving the 5100s at the lowest height and get aftermarket springs. I got Old Man Emu 883 springs for the front. It levels the truck out.
2004 SR5 4WD | 5100s | Level 8 MK6s
newton22 is offline   Reply With QuoteReply With Quote
5100s , front , ordered , springs , struts
Bilstein 5100 shocks work on 5th gen front springs? hdoggie24 3rd gen T4Rs 8 12-10-2020 11:48 AM
Bilstein 5100 Front Springs Chilow 5th gen T4Rs 5 02-12-2019 11:40 PM
FS: 3rd GEN front bilstein 5100 and springs, $100 Chino, CA battery1882 For Sale: T4R Items 5 12-07-2016 12:52 PM
FS- Bilstein 5100 Front and Rear Shocks w/FJ Springs-NJ Scoward For Sale: Suspension/Wheels/Tires 4 08-22-2014 06:16 PM
FS: Front Bilstein 5100 & FJ Springs Greydog For Sale: Suspension/Wheels/Tires 7 03-16-2013 12:20 PM
