Old 12-31-2020, 10:04 AM #16
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
Originally Posted by 81runner View Post
Do you have the pair side by side in the oem location or did you have to mount the second elsewhere? I'm looking into getting a pair of 31s under the hood
one in oem location, my second one is in the trunk, its close to my sub amp that is in the storage area.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 10:23 AM #17
riceandpho's Avatar
riceandpho's Avatar
yes agm weighs more, but you need to think about the technology, sealed and you can mount anyway you like, i used to run the sears die hard platnums, no mods needed, they were a little bit shorter at the post, thats why the oddy fits better, you can go to batteryplus and get there x2, now northstar and oddy is one company, order online and use coupon code and do store pickup. i also think that the post area is a little different with my northstar. i was the lucky one to buy these battery in a group buy.
yes the 31m im using is high, maybe its due to how the terminals are, stud and post mount they use.
group 31 weight 75 pounds
group 27 weight 68 pounds
group 24 weight is 57 pounds,
i wouldnt care too much about weight, when you should be thinking of having a higher capacity.
i used to run oddy pc1700mjt, these were the size in the european cars, it was a little on the short as in height, but wide like group 31. i think i used a block of wood at the top to use stock battery hold down.
Originally Posted by hinmo24t View Post
i respect your reputation and knowledge, but the underlying factor is i dont want to modify anything to fit the new battery. no contact with hood, terminals too high or far apart. just a perfect fit drop in 24 AGM. i can only think of the diehard and duracell referenced in this thread so far. i dont want a 27F because of the 30% (its over 25% i believe) extra weight. dont want a 31 that hits hood or has tight connection.
the odyssey (34 i think, some agms used those #s for their 24f size) might be a good fit but i heard of some pitfalls with those, or at least nothing to confiding in terms of fitment. i think those odyssey or red top even need the oem clamp to be proected with rubber because they need to sit offcenter with a terminal then .5" away from metal battery tiedown...no thanks
optima red tops need a shim and stretch cable (the ground and positive i think are super tight, with red top positioned off center of tray to begin with)
the X2 i posted about might be a good fit but i cant really confirm it as of now. edit, thanks @metramm
thats a very slick battery ^
its a northstar relabelled and fits perfectly...hmm might be my battery. battery plus has them for $230 near me
Old 12-31-2020, 10:30 AM #18
riceandpho's Avatar
riceandpho's Avatar
heres a old pic. you might see a difference from the northstar and die hard / oddy
Large group 31 Battery with low voltage disconnect (any one else done this?)
Old 12-31-2020, 10:39 AM #19
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Pic no worky.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 10:48 AM #20
riceandpho's Avatar
riceandpho's Avatar
Originally Posted by xtremewlr View Post
Pic no worky.
forgot to link this older thread.
Old 04-14-2021, 08:00 PM #21
DirtyDanno's Avatar
DirtyDanno DirtyDanno is offline
DirtyDanno is on a distinguished road
DirtyDanno's Avatar
What did you end up doing?
Success is not final, failure is not fatal: it is the courage to continue that counts
-Winston Churchill
DirtyDanno is offline   Reply With QuoteReply With Quote
Old 04-16-2021, 02:55 PM #22
Nickname's Avatar
Nickname Nickname is offline
Nickname is on a distinguished road
Nickname's Avatar
Is there a reason OP is going with a 24F? I thought that a 27F was the standard battery for our vehicles. I have a X2 27F and it fits perfectly with no modification.
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread:https://www.toyota-4runner.org/4th-g...ld-thread.html
Nickname is offline   Reply With QuoteReply With Quote
Old 12-21-2021, 06:33 AM #23
YusukeKohara YusukeKohara is offline
YusukeKohara is on a distinguished road
can anyone tell me whos dropped in a 24f agm with no modifications with shims, stretching or extending cables? just flooded info everywhere on it. looks like maybe the diehard one except people say its super heavy for an agm (then again they say its a redtop in a different cover)...but the red tops need a shim and cables barely fit i heard, have to stretch them extra.
i like the X2 24f version, not positive if thats a good fit with stock tray and cables?
im replacing an old 24f ac delco ive had it for 3ish years and it didnt start one time i left music on or something a bit too long. good battery. almost considered going with typical fresh walmart BJs interstate etc battery but i wheel and live in cold area, adding winch and small lightbar soon, and wouldnt mind the cleaner battery.
if you could chime in on if you need to trickle charge (special with agm?)
id almost consider going regular new 24f battery if my 2004 alternator i run thru water wont handle the charge of the agm and i have to charge it every few mos or so. i tend to have a lot of short commutes and wheel every week or two. read from honest source a regular battery and lightbar + winch used reasonably will be fine too.
dont want to run big heavy 27f or modify anything once again
thanks
Thanks for writing such an interesting article. I'm glad your guidance helped me. All cars rely on some sort of battery for cranking the engine and powering all the electronics. But making sure that you are getting the right sized battery for your car is quite important. And since most cars rely on 24F batteries because of their standardised size 24F battery to be compatible with your car not only in terms of its size but as well as the voltage. This is important to check so that all of the electronics of your car can be directly powered by your car’s battery. As a result, all 24F batteries given here are 12 volt ones for high compatibility.
YusukeKohara is offline   Reply With QuoteReply With Quote
Old 02-07-2022, 01:25 PM #24
Ripper238's Avatar
Ripper238's Avatar
My question is why do a 27 or 31 when a 24F is the correct size and has more capacity depending on model.
Old 02-08-2022, 03:24 PM #25
Nickname's Avatar
Nickname's Avatar
I'm not a battery expert, but I believe 27F has more reserve and CCA than a 24F. At least this is true for the X2 power batteries which is what I have.
24f , agm , battery , cables , charge
Odyssey battery size fitment ? Grug556 5th gen T4Rs 2 11-22-2019 03:33 PM
Fitment Question. 6wheelin 4th Gen T4Rs 3 01-19-2018 05:48 PM
TRD exhaust fitment question 3rdgenfan 3rd gen T4Rs 6 07-30-2014 11:30 AM
Odyessey battery fitment issue ron in sc 5th gen T4Rs 8 08-29-2013 11:16 PM
Dual Battery - Group 34 fitment? Mick1 5th gen T4Rs 4 11-21-2012 04:08 PM
