Old 12-29-2020, 06:58 PM #1
ad_robotics ad_robotics is offline
ad_robotics is on a distinguished road
Compressor quick connect - exterior
I'm looking for some ideas. I've installed an ARB air compressor into my engine bay and would like to find a spot where I could place a hose quick connector so that I don't need to pop the hood every time I want to air back up.
Has anyone here seen any setups that have an exterior mounted hose quick connect?
2005 Limited V6 4WD
ad_robotics is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 07:31 PM #2
Nickname's Avatar
Nickname Nickname is offline
Nickname is on a distinguished road
Nickname's Avatar
I had a couple external quick connects and they were a pain. Always getting corroded and not making good seals. I moved mine right inside the rear window. I roll it down quick, air up, and roll it back up. Easy and no corrosion.
Here's a link with some pictures. https://www.toyota-4runner.org/3548618-post7.html
06 Galactic Limited on 33's, Rear locker, Bilstein 5100s, Toytec 2" Superflex Springs, Whitson Metalworks Rack, Squadron Sport Ditch Lights, Dual Viair 450cc Air compressors with 2.5 gal tank, Cobra 75WXST CB Radio
Build Thread:https://www.toyota-4runner.org/4th-g...ld-thread.html
Nickname is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 08:01 PM #3
Nice, just what I was looking for.
What kind of hose did you use in the engine bay that connects to your compressors?
I'm thinking that they need to be high temperature tolerant, not like the standard PVC or rubber air hoses.
2005 Limited V6 4WD
Old 12-29-2020, 11:00 PM #4
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I use rubber transmission line under the hood. I drilled out a hole in the driver wheel well and mounted a bulkhead fitting and a QD with a dust cover. Tire never gets close to it, I've been off road with it many times
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 10:47 AM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I used an ARB quick disconnect system for my truck mounted through my rear bumper. Has worked really well with a coiled hose I can reach all my tires.
I've since added the ARB cap to it after taking this picture.
Inv4drZm is offline   Reply With QuoteReply With Quote
air , compressor , exterior , hose , quick
Mounting quick-connect plugs? mstreck 4th Gen T4Rs 0 01-21-2020 12:39 PM
Quick Connect Awning attachments Bikemedic 5th gen T4Rs 23 08-11-2017 08:58 AM
Brand New Deltran Battery Tender Quick Connect Harnesses - $10 [Bay Area, CA] cutty01 For Sale: Non-T4R Items 0 07-12-2017 12:40 PM
Advice for wiring a warn quick connect winch harness tnine 5th gen T4Rs 9 04-22-2016 06:47 AM
Air pressure gauge and air hose quick connect Okki 5th gen T4Rs 7 10-08-2012 10:28 PM
