09-18-2010, 12:21 AM
Well im an idiot... drove with parking brake on
Hey guys so Im sure this question has been asked and answered before... unfortunately now its my turn. The other day I forgot to take my parking brake off and didn't realize it until i got onto the freeway and got to about 45-50 MPH and heard a thunk thunk thunk noise and couldn't really get her to go faster and realized yea Im pushing harder on the gas than usual. Since then I haven't noticed anything unusual when driving but I wanted to make sure there isn't something I could have messed up that i might not notice immediately. And is there anyway I can adjust it to be tight again... and to have full disclosure i have done this before but noticed it within like 20 feet so my parking brake has already softened up some. TIA
2006 Silver Limited; Headrests w/ dvd, 35% tint over stock tint, OW 2.0 Coilovers and rear shocks, SAW rear coils, Procomp 7005's, Dunlop Maxx Traction M/T
09-18-2010, 01:20 AM
Real Name: Doug
Real Name: Doug
Should have called it the "Make your car smell funny lever" RIP Mitch Hedberg
But honestly, I can't really give you a real answer but I can say Ive driven with my emergency brake on and never had any wrong come from it. But then I have never had a "thump, thump" sound.
Sorry I couldn't be more help.
09-18-2010, 01:41 AM
Did it not beep like crazy? If I drive with my parking brake on my '08 T4R beeps like my '07 Tundra's "sonar" sensor beep when you get too close to something.
CURRENT: '14 Limited Mag Gray, '17 Limited Mag Gray, '19 Mercedes GLC300, '08 Urban Runner | SOLD: '96 4runner SR5, '08 Urban Runner, '14 Limited Blizzard Pearl
09-18-2010, 04:20 AM
Parking brake shoes are a wear item, just like shoes would be in a drum brake setup. You likely wore it down a fair amount. You might be able to adjust it, but I'm not sure how.
It's probably not too bad. These parts are designed to slow the vehicle down in case the brakes completely fail.
09-18-2010, 07:08 AM
I have done that a few times, mostly in a the early days of ownership, because there is so little resistance to moving forward, its odd. O5's dont have a warning beeper. Never had anything come of it, but I expect they would adjust during services.
2017 Lexus GX460
2016 BMW R1200 GSA
2005 4Runner V6 4WD Sport Edition
1991 VW T3 Caravelle Syncro RHD
09-18-2010, 08:21 AM
There is no adjustment for disc brakes, only drum brakes, and they are self adjusting by driving in reverse and tapping the brake pedal. This should not cause any damage, except it has worn your brake pads down some. I don't understand the thumping noise however. I would probably take it and have the pads looked at unless you know how to do that yourself.
RickC
2003 Toyota 4runner Sport V6 4x4, Daystar 2.5/1.5, Enkei ST6 18x8.5, Toyo Open Country AT2 285/60/18, Scion FRS Touchscreen head unit with NAV and backup camera, LEDBARZ 41" light bar.
09-18-2010, 08:52 AM
The 4th gen runners have small drum brakes inside the center of the rear disc brake rotors for the parking brake system. They do not self adjust, like earlier regular drum brake systems. However, they can be manually adjusted. You have to remove the rear wheels, and then you can access an adjustment wheel inside the rear disc from the outside using a small hole in the rotor. This has been discussed several times in earlier threads, and there may be a write-up on it.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
09-18-2010, 09:28 AM
I drove in the parking lot until I noticed the light before. It's either a good advertisement for the engine's power or a knock against the parking brake.
2001 SR5 4X4, V6, 3.4L
09-18-2010, 11:29 AM
Super Moderator
Super Moderator
Did it a few times and 5.5 years later, no problems. Don't worry about it!
Mark
2005 4Runner Limited 4X4 V8 since 6/15/05 Titanium Silver with Grey Leather
Nav, XREAS, Adjustable Ride Height, Sunroof, Side Curtain Airbags, Rear Spoiler, Double Deck Cargo, Chrome Exhuast Tip, Bug Shield, All Weather Mats, Driver Side Assist Handle, Audiovox Remote Starter, 2006 Skid Plate, LED lighting- interior and running boards, USA-Spec PA-15
Click For Pictures of My Current 2005 Limited, Detailed LED Conversion Instructions, Click For Pictures of My Retired 2003 Sport
09-18-2010, 04:20 PM
thumping noise
when i first took test drive on my 06 t4r i left the parking brake on. My sales man had the exact same model and could tell he wasnt full of bs. The thumping noise came on as well. And he mentioned that the brake was still on by hearing that thumping i had no idea. was traveling prob 40+. Since then driven 6k milles w no prob. Dont know if it matters but my girl left her brake on for hour plus in her prius. toyota's r solid.
Shane
06 4runner SR5 4x4 silver-TRD intake, de-badged, 3/2 cornfed, FJ springs/shocks, 285/70/17 BFG's, diff drop kit, swaybar bushing upgrade, spidertrax, tint
09-18-2010, 04:36 PM
Does that charge the battery, or just the regular brakes? LOL.
09-18-2010, 06:59 PM
lol quality.
Shane
09-18-2010, 07:53 PM
I've done it too and I feel like there might have been some thumping involved before i noticed it. Never have had any issues and that was over a year ago. I wouldn't worry about it.
2007 4Runner Sport Edition 4WD V8 | Black | Heated Leather Limited Seats Installed | BFGoodrich All Terrains 265/65/17 | Black Pearl Emblems | 20% Tint up front | Plastidipped front grille | Weathertech Digital Floor Mats | Alpine INA-W900BT head unit | Alpine KTP-445 HU Power Pack | Alpine Type-R Speakers | JL 10W7 Sub in JL Stealth Box with JL Slash v2 Amp | Dynamat added on all doors and gate | Clifford 50.7x Security System and Remote Start | LED Full Interior and Exterior Light Swap | XenonDepot 4300k HID kit for low-beams
09-18-2010, 08:27 PM
The engine is great, but the unfortunate truth is that the parking brake system on the 4th gen is marginal at best. Because the brake shoes used are quite small, with a much reduced swept area compared to earlier models with rear drum brakes, they barely work as parking brakes, and are not to be expected to work as an emergency braking system.
09-19-2010, 02:53 AM
My 06 does not beep what-so-ever when the parking brake is left on, it really kind of makes me mad that there is no warning besides a light blinking on the rpm gauge. Dumb. But other than that yes you can tighten it up, I am pretty sure it is just a wing nut type thing. (I don't know for sure, that is what my 06 Mustang GT had though cause I had to tighten it a couple times
2006 4Runner Sport V8 4WD Satoshi Grille, Magnaflow exhaust, K&N filter; Shrockworks bumper, Overland Warehouse 2.0 Radflo full kit, 33 inch Mud Grapplers on 20 inch Rockstars. HID Kit, Blacked out Headlight Housings, Tinted tail lights, LED license plate lights, LED running lights and turnsignals. De-badged all around. 2% tint all around with 30% all the way down windshield. Kenwood Double Din 7 inch headunit. 2 Alpine Type R 12" subs with 2 Alpine 500 watt Mono Amps and a 6 farad capacitor. All interior lights swapped for LED's. Train Horn mounted where spare tire was. WAR EAGLE!
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
