So on my Pass bank manifold has developed a horrible leak. I have managed to fix it.
Tools needed:
Shop Vac
10mm to remove air filter tube
Exhaust cement
Heat gun
24 hours of time
I managed to apply a ludacris amount of muffler cement after cleaning the manifold. In fact the hole was below. I used a shop vac to find the leaks. There was just one really big one.
At this point I am having to now save for DougThurley headers since this paych will probably be the last fix before the manifolds dissentegrate. Please do not put negative pressure if the hole is big or cement will just go through hole.
Tapatalk Cloud - Downlaoad File Snapchat-1010272058.mp4
Sent from my SM-N986U using Tapatalk
