Old 01-05-2021, 10:43 AM #1
Captsolo Captsolo is offline
Captsolo will become famous soon enough
2005 transmission (4 speed) Type IV shudder solved
"I was able to fix the issue with my 2005 4Runner LTD 4x4 regarding the strong vibration (as if going over a rumble strip) with light acceleration. I put a one ounce bottle of a friction enhancer in the sealed transmission and the issue was solved. I was initially told that I needed to replace the transmission, then it was the torque converter. The bottom line is, the transmission was serviced with other than WS fluid and the viscosity did not match what was needed. The friction enhancer stopped the torque converter from shuddering (torque converter shudder) and it has been fine through 205,000 miles. It took a bit to find the transmission plug to pour the friction enhancer into, but the transmission has worked great ever since."
This was a copy and paste
Any calm educated responses are welcome
Vibration/shudder: Six Cylinder Two Wheel Drive Automatic 139,000 ...
Captsolo is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 12:50 PM #2
calm educated reply: the copy & paste quote clearly says the trans uses WS fluid & he used the "fill plug" on the trans, which means its a 5 speed, not a 4 speed with a dipstick & T-IV fluid.
many people have reported using the shudder fix additive helped the shudder issue regardless of fluid type. many also say just changing the fluid with WS or maxlife which is a full synthetic universal fluid rated for WS improved the shudder issue.
Old 01-05-2021, 01:37 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Here we go again.
There are NO 4speed 2005.
There are NO sealed 5 speeds...whoops...
That should have read there are no sealed 4 speeds.
(Thanks for pointing that out firebirdguy)
The 5 speed is WS.
The 4 speed is T-IV.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 01:52 PM #4
Originally Posted by BackOff View Post
Here we go again.
The 5 speed is WS.
all correct info, but 5 speeds are usually called "sealed" just not completely sealed up... just means they dont have a dipstick to fill & check fluid like 4 speed T-IV trans. have to do it via the check plug to check level & fill plug on the side of the trans to fill. but i know what you meant.
Old 01-05-2021, 03:38 PM #5
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Lol...thank you.
Yup see i screwed up...how easy to do.
And easy to admit to.
5 speed IS sealed.
Guess that should have been.
There are NO sealed 4 speeds.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 01-05-2021, 07:53 PM #6
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Lol...thank you.
5 speed IS sealed.
Just to clarify, there are 5 Speeds with a dipstick, the 2003 5 speed for sure and possibly the very early 2004 5 speeds had dipsticks and use the same T-IV fluid as the 4 speed does, most if not possibly all 2004 and onwards 5 speeds are the sealed version and use WS fluid.
2004 Limited V8
Old 01-06-2021, 11:52 AM #7
Talking
my 2005 4runner doesn't have a dipstick and the dealer used Type T-IV (it's a sealed tranny) when they did the tranny service at 105,000 miles. Shifts fine - just like new in 2005.
I personally will not change to a different brand of T fluid. Just Toyota recommended Type I-V
Over 150,000 miles and the OEM engine and tranny work perfectly. No slip. Plenty of power for a V6.
synthetic is overrated IMO. Change the oil every 5000 miles.
Old 01-06-2021, 12:53 PM #8
ok, thanks for confirming that. if youre 4runner doesnt have a dipstick & is "sealed" then it is a 5 speed & it calls for WS fluid. the fact your dealer used T-IV is only because, as you said before, they just couldnt get WS. doesnt mean its the correct fluid toyota says to use & it didnt come with it when new. if you want to use T-IV thats your choice.
& the synthetic statement was about valvoline maxlife trans fluid, not oil.
Old 01-06-2021, 03:02 PM #9
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
2003 V6 5speed?
Have links to that info?
Even my 2004 built in 03/9 is a 340 4speed.
I have never seen any V6 T4R 2004 or before have anything but the 340 trans, with a dipstick and the 4speed.
After the 750 5speed it went sealed, with the "lifetime" BS fliud (import tax dodge).
...i am not trying to argue with any of you guys.
Happy to learn, if wrong i have no issue with that.
I was just trying to keep others from putting T-IV in a WS transmission.
...how the hell did i get in this thread...
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 01-06-2021, 06:17 PM #10
Cool
#1 Toyota's official statement is that transmissions with T-IV fluid in them should always have T-IV in them. No swapping to WS or anything else
#2 Toyota does not approve of Maxlife for use in any of their transmissions and they have not tested it (Valvoline will tell you this)
#3 Valvoline says Maxlife is "Suitable for use" to replace pretty much any Toyota trans fluid including T-IV & WS and several reputable members have reported good results using it in multiple vehicles
When I had the dealer service my 2005 4runner at 100,000 miles they used T-IV transmission fluid by Toyota.
I have 150,000 miles on my transmission so I will continue to use T-IV in my next D/F.
I have the 4-speed and its a sealed transmission.
I'd be afraid to use anything else after 15 years with T-IV - and nothing else.
Old 01-06-2021, 07:24 PM #11
Real Name: Skip
Real Name: Skip
2003 V6 5speed?
I never mentioned the V6 engine, only 5 speed transmissions.
All 2003 and 2004 V6s had the 4 speed transmissions.
2003 V8s had the non-sealed 5 speed, and as I mentioned that possibly the very early 2004 V8s also had the non-sealed 5 speed, but I'm not certain that the case, I have a mid year build 2004 with a V8 and it has the 5 speed sealed transmission.
2004 Limited V8
Old 01-07-2021, 03:15 PM #12
BackOff's Avatar
Real Name: Derek
BackOff's Avatar
Real Name: Derek
Sorry AuSeeker i was talking v6 4runner because thats what captsolo said he had, thought we were all on the same page with captsolo.
Still it would be nice to see this 2005 with a sealed 4speed.
Would shut me right up! LOL
Maybe its the first one before the 05 switch to sealed 5 speeds?
Or Euro build?
Whats the build date captsolo?
Can you at least give that much info?
I was just harassed out of a JBA uca thread on TW, for asking questions.
I am just here to learn.
Like when there was a rash of SPC ucas with the balljoint installed backward.
I would try and point this out so it can be remedied and to try and help others for making the same mistake.
/cheers
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
Old 01-09-2021, 08:50 PM #13
My 2005 4runner came to the dealer from Japan. I am in Nassau Bahamas. And, yes, it has no (tranny) dipstick. I bought it off the Toyota dealer's lot here in the Bahamas.
I had the dealer do a 5-quart D/F of tranny fluid at 100,000 miles, but have to bring it to them again now at 150,000.
Might try the D/F myself. Not sure. T-IV they told me they don't have any left, and that's what the dealer used the last D/F. I got 5 quarts of T-IV. Tranny holds almost/about 12 quarts in 2005. Mine did not come with WS. T-IV and WS are not compatible.
Getting 150,000 miles out of transmission blows my mind, but I've read of some 4runerrs with 300,000 miles on their original transmissions.
Engine/car still runs like a top. No rust on the body anywhere in 15 years.
Old 01-09-2021, 09:25 PM #14
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
I believe all 4th gen 4R come from Japan
[QUOTE=Captsolo;3589647]My 2005 4runner came to the dealer from Japan.
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 11:13 PM #15
Real Name: Skip
Real Name: Skip
All Toyota 4runners came to the dealers from Japan, no matter where you live, the 4runners are only built in Japan.
Also all the 4runners with the sealed transmission came from Japan with WS fluid in the transmission, so when your dealer use the "5 quarts" of incorrect T-IV fluid they mixed it with the WS fluid it came with!
2004 Limited V8
converter , enhancer , friction , torque , transmission
Transmission shudder WHEN STOPPING? 81runner 4th Gen T4Rs 12 07-31-2023 12:53 PM
Weird slow speed shudder (20-30mph on small hills) logcabinwc 4th Gen T4Rs 27 09-23-2019 05:26 PM
5th Gen T4R transmission shudder lllzzz79 5th gen T4Rs 45 06-15-2018 05:57 AM
Low speed shudder? jcush87 3rd gen T4Rs 6 11-09-2017 02:01 PM
Shudder - transmission or engine? zcruiser 3rd gen T4Rs 34 12-15-2011 12:09 AM
