Old 01-07-2021, 07:06 PM #1
AzCasper's Avatar
AzCasper AzCasper is offline
AzCasper is on a distinguished road
AzCasper's Avatar
Eibach Lift and LCA update
Picked her up from the alignment shop and took her for a ride. I am VERY happy with the results. Road manners are vastly improved. Took a small detour down a Forrest Road and enjoyed the improved ground clearance and ride.
Fine print: I purchased this 2004 V8 Limited knowing the XREAS was toast.
I assembled the front shocks and springs on the second clip from the bottom, using new top plates. Lower control arms were replaced at the same time, as the alignment bolts had to be cut out. Alignment hardware was replaced with Factory Toyota parts.
Eibach Lift and LCA update-snow-4runner-jpg
'04 V8 Limited - Eibach Pro Truck lift, TRQ LCA, TPMS bypass
AzCasper is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 08:51 PM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Hey thanks for PMing me and getting me to this post. Looks good! So remind me, you bought the full Eibach Pro Truck Lift (Stage 1), right?
You set it on the second lowest clip. According to the install docs, that should net 3.4" of lift. Did you happen to take before and after measurements?
What size tires are you running?
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-07-2021, 09:52 PM #3
AzCasper's Avatar
AzCasper's Avatar
It is the full kit...4 springs and 4 shocks. Eibach says 1.8" lift with the V8 4Runner, so I used the second clip from the bottom.
I didn't bother with before measurements because the XREAS system had leaked dry.
Tires are stock size 265/65-17 Coopers.
Old 01-07-2021, 09:55 PM #4
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Looks great! Didn’t even consider the V8 being that much heavier. What’d they say the second clip should be for the V8?
Old 01-07-2021, 10:43 PM #5
AzCasper's Avatar
AzCasper's Avatar
I called Eibach and they said it should be level on the second clip. I can't say enough good things about my experience with Eibach!
Old 01-08-2021, 10:21 AM #6
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
That's funny, on mine the first clip was pretty much level. It always amazes me how much variance there is with these lift kits...
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:26 PM #7
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
V8 or V6? I’m leaning on the lowest setting to keep a little factory rake. On Eibach site it shows 1.8” front and 1” rear for V8. On the V6 it shows 2.75” front and 1” rear.
Old 01-08-2021, 04:27 PM #8
little_joe little_joe is offline
little_joe will become famous soon enough
I installed the kit on my v8 4R at the lowest clip and got a slight rake - I like it, and when loading the rear, it sits level. Rides great.
little_joe is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 05:00 PM #9
AzCasper's Avatar
AzCasper's Avatar
I used the second from the bottom because I will be adding a steel front bumper and winch soon. With the added weight of the V8, I was concerned about the front end being too low. It is level now, so I expect it to drop a bit after the bumper and winch install.
Old 01-08-2021, 05:32 PM #10
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
Would anyone else mind positing pics? Pre and post lift? Please add the details to lift perch setting, wheel size, etc... thanks!
Old 01-08-2021, 06:10 PM #11
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
Not sure if this helps but here is my setup with the Eibach shocks and OME885 first perch and OME895 rear. 265/70/17 with the spidertrax spacers.
After a lot of reading I wasnt a fan of the springs that came with the kit because of the lift height and a lot of people had a lower rear compared to front. That why I went with the OME setup.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
alignment , improved , replaced , ride , road
Educate Me on my Eibach Lift 4'running'26 5th gen T4Rs 6 12-22-2020 01:47 PM
Bilstein 5100/ eibach springs OR Eibach pro truck lift system? T4R416 5th gen T4Rs 28 12-08-2020 05:21 PM
TRD Pro Kit vs. Eibach Pro Truck Lift Kit @jrfordlandia 5th gen T4Rs 12 10-20-2020 07:14 PM
Tundra 5100s with Tundra Eibach Coils (UPDATE with PICS) cbr900boy 3rd gen T4Rs 16 07-15-2019 12:08 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
