Old 01-10-2021, 12:43 PM #1
Warwicke36's Avatar
Warwicke36 Warwicke36 is offline
Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough Warwicke36 is a jewel in the rough
Warwicke36's Avatar
06+ 4.0 engine direct swap for 03 to 05?
I have an 04 v6 that loses about 1 to 2 ounces of coolant every 1000 miles. No visible external leaks and 201k on the odometer. I suspect head gasket or cracked head. I have no other symptoms and just top up every once in a while. I bought it this way sadly but it hasn't seemed to get worse luckily.
I have the ability to do head gaskets or an engine swap and I am leaning towards swapping a low mileage 06+ engine in. That will get me the new gasket design. Is the motor a direct swap? Thanks for any info. Please don't turn this into a "you should do this or that instead" thread. Really just looking for info on compatibility. Thanks!
2004 Sport 4.0
Warwicke36 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 01:51 PM #2
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
I'm not sure about compatibility, but I would start my research by comparing part numbers for various components, such as engine ECM, wiring harnesses/schematics, etc., if I'm not mistaken the early 4th gens use a different Bus/Can protocol so I'm guessing the ECM would have to be swapped, and the wiring harnesses are most likely different so either they would have to be swapped or adapters made.
That being said the savage yard type websites should give the choice of compatible engine year models, which should be much easier to find the answer to your question.
2004 Limited V8
Old 01-10-2021, 02:20 PM #3
Warwicke36's Avatar
Warwicke36's Avatar
Thanks for the info. I'll call BOW in NH as they are who I normally use for used motors and transmissions. Sometimes they don't want to do any cross reference for you though. We had a same year/model where the flex plate was different... It didn't get noticed or swapped before install (shame on me) and it didn't fit so it got done twice. Trying to avoid that kind of thing for sure.
2004 Sport 4.0
Old 01-10-2021, 03:38 PM #4
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
Something about the cam or crankshaft position sensors is different on the early 4th gens. Like AuSeeker said, I think it has to do with the different ECM stuff and how everything communicates. I'm not completely sure, but maybe those keywords can get you headed towards a solution.
I feel you on the coolant slowly leaking somewhere probably internal. It's been a tad more than a year and like 8k miles and I'm down about 3" in the reservoir from when I last filled it. No pink crusties anywhere to be seen externally. Early v6 gang lol
y=mx+b is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 03:48 PM #5
Warwicke36's Avatar
Warwicke36's Avatar
Haha for real. I basically don't even care about the coolant loss unless it gets worse. I'm a tech by trade and it bugs me but not enough to freak out over it. I'm in Maine so the rusted exhaust manifold stud/nuts are enough to dissuade me from diving right in. But should the day come I want to be prepared. Knowing myself I will get the urge one day on a whim and start tearing into it.
2004 Sport 4.0
Old 01-10-2021, 04:04 PM #6
y=mx+b's Avatar
y=mx+b's Avatar
Yeah, right now it's minimal enough that I'm not too worried about it. It always a tad unsettling that something's wrong, but I'm just gonna suck every last bit of life out of it lol. Mine came from PA and was sold in VA and I didn't know much of anything about cars when I bought it, so I also have those rusty exhaust bolts and a little bit of crusty everything that scares off me from anything engine related right now.
Hopefully nothing gets worse and you can keep on chooching!
Old 01-10-2021, 04:19 PM #7
The G-Man The G-Man is offline
Real Name: Gary
The G-Man is on a distinguished road
Real Name: Gary
Have you tried to source a used engine? Everywhere I have looked (looking at swapping myself instead of replacing HG) wants $2000+ for a 1GR-FE. Which seems like a high price for such an ubiquitous engine.
Idk maybe I’m just used to my days dealing with 90s Honda’s... you could have a Prelude H22 long block for $1500
The G-Man is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 08:07 PM #8
Warwicke36's Avatar
Warwicke36's Avatar
I haven't called yet, but I wouldn't care about 2k that much TBH if it has 100k on it or less. I'd be tempted to do the headgaskets with it on the engine stand before installing it. Potentially timing chain too.
But again, being a New England vehicle I try to keep myself under control with spending. At some point im better off using the money for a down payment on a 5th gen. I just really prefer the 4th gen body style.
Ahhh decisions are fun.
2004 Sport 4.0
Old 01-10-2021, 10:35 PM #9
Real Name: Gary
Real Name: Gary
Sorry I was a bit mistaken... Car-part.com search has low mileage ones listed for $3k+
Old 01-11-2021, 11:19 AM #10
bricew25 bricew25 is offline
bricew25 is on a distinguished road
Ya, I believe 03-04 had something different with the motors. If I look at car-parts, an 04 4Runner gives a limited selection of motors, but if I look under 05, I have a lot more options.
Im currrently having someone do a swap right now and I just picked up a 2011 Tacoma motor for my 05 4Runner. The prices for any 1GRFE are crazy on that site though. I had someone local offer the motor from a Tacoma w/ 125k for $1200 so I jumped on that.
bricew25 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 11:27 AM #11
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
surprised this thread hasn't been mentioned;
The Engine Is A Goner, Warped Head And Long Block!! - Page 4 - Toyota 4Runner Forum - Largest 4Runner Forum
Goes into detail on what happened when he tried to install an engine that wasn't his exact year/spec/etc.
CookieRoe is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:09 PM #12
Warwicke36's Avatar
Warwicke36's Avatar
Thanks Cookie.
I was cautiously optimistic.
Back to the drawing board it seems.
2004 Sport 4.0
Old 01-11-2021, 03:40 PM #13
Real Name: Gary
Real Name: Gary
Dang where you at? I’d jump on a $1200 motor in a sec
Old 01-11-2021, 04:45 PM #14
Im in Utah. Prices for anything toyota is so expensive right now, so I lucked out. At first I was going to buy another 4Runner, but couldnt believe what people were asking.
Old 02-15-2024, 11:49 AM #15
83thihan 83thihan is offline
83thihan is on a distinguished road
Has anyone got this engine swap working?
Sent from my SM-S928U using Tapatalk
83thihan is offline   Reply With QuoteReply With Quote
06+ , engine , head , info , swap
Suspension Noob Question - Is This Tacoma TRD Setup a Direct Swap? Bluesky 07 4th Gen T4Rs 31 09-04-2020 12:50 PM
my 92 budget build. engine swap and front end swap? bhenry92 Classic T4Rs 4 08-06-2013 05:42 PM
Direct Injected Engine for 2014??? SOcalTRAIL 5th gen T4Rs 0 08-08-2012 01:36 PM
94 4runners-engine swap, or front end swap? pats for sale as well jimmy94 Classic T4Rs 7 05-16-2011 09:48 PM
Is the OEM JBL navigation head unit a direct swap for the standard JBL? clarky007 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 07-15-2009 09:28 PM
