Old 01-10-2021, 12:57 PM #1
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Diff Drop Needed after 2" Front Lift?
So I have a little grease flinging out where the inboard CV boots meet the axle shafts after installing Bilstein 5100s set to the third notch. This setting was supposed to only provide 1.75 in of lift but actually provided 2" of lift after a couple of days of settling.
I noticed there was dirty grease buildup around the boot where it is supposed to seal around the CV shaft when I did the job. I wiped it clean when I did the lift. So I don't know if removing that buildup caused the grease to start to fling out or doing the lift potentially did because I was moving the CV shaft and boots in and out when I was doing the job.
The clamp is not tight as I can move the boots on the shafts by hand.
I'm considering the McMaster-style hose clamps to fix the leak. But my question is do I really need to do a diff drop could that be part of the reason the grease is leaking?
I have no ribs of the CV boots touching each other and it looks like if I did a dip drop it would actually increase the angle because the diff is actually slightly lower than the hubs on the wheels. There is actually a slight bit of negative angle of the CV shafts going to the wheels.
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 01:06 PM #2
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Diff drop should not be needed. You most likely just need to replace the inner CV boots.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 01:15 PM #3
My T4r has 36,000 mi on it and the boots are soft and supple with no cracks or tears. I see no reason to replace them at this time.
I thought when you lift you are supposed to get a downward angle from the shaft going from the diff to the hub?
Old 01-10-2021, 09:17 PM #4
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
Then you probably just need to replace the outter clamps, especially if the boot it sliding around.
Downward CV angle all depends on how much lift you do. If you gained lift and they are still relatively flat, I wouldn't worry about it as long as everything else seems in good shape.
Old 01-10-2021, 10:35 PM #5
aemravan aemravan is online now
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
If its not torn put the McMaster worm gear style clamp and forget it. No issues since I've gone that route.
Sent from my SM-G970U using Tapatalk
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is online now   Reply With QuoteReply With Quote
Old 01-10-2021, 10:36 PM #6
Ok perfect I ordered the clamps. Thanks!
Old 01-11-2021, 02:30 PM #7
bmorey bmorey is offline
bmorey is on a distinguished road
Could you throw those part numbers from McMaster on here? That would help a ton - thanks ahead of time!
2004 4Runner Sport Edition 4WD Titanium Metallic -
Ironman 4x4 Lift and UCAs, 33s Falken Wildpeaks, Custom 2-Drawer System, Prinsu Rack, Frontrunner RTT, Ironman 4x4 Awning, Cali Raised Sliders, 1 Inch BL, Lost Trails Low Profile Front Bumper, Badlands Apex 12k Winch
bmorey is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 03:42 PM #8
I actually ordered the small kit from Amazon from Patriot Parts I think his name is. I paid around $14 to get Prime shipping but if you look on Ebay it is the same seller for a few dollars cheaper but it will take around a week to get the package.
Just search "lift cv boot clamp 4runner" on either Amazon or Ebay and you will see the listings. If you want to buy enough to do all the fittings on both CV shafts the price goes to around $20. I only needed 2 of the small clamps for the inboard boots so I ordered the small kit.
boots , drop , grease , lift , shafts
FS: 3rd Gen 2" Body Lift & Diff Drop Clayton74 For Sale: Suspension/Wheels/Tires 0 05-23-2016 09:05 PM
Front diff drop needed for 3" OME lift kit? benjamin247 3rd gen T4Rs 12 03-10-2016 07:15 PM
FS: 3" OME lift with diff drop! 3rdPedal97 For Sale: Suspension/Wheels/Tires 12 12-01-2012 10:10 PM
FS 3Rd Gen 1" BL and/or Front Diff Drop kit corny For Sale: Suspension/Wheels/Tires 13 01-30-2012 11:37 AM
FS 3rd Gen 1" BL and/or Front Diff Drop kit corny For Sale: T4R Items 1 12-12-2011 10:33 PM
