Originally Posted by boondoggle
Seems odd to me they would put larger rotors on but, from what I understand, the pads are the same size as other models. So, my pea brain tends to think I'm getting the same amount of friction when the brakes are on. It's still a two piston caliper from what I've read.
Other than perhaps better heat dissipation due to more mass and larger surface area, I don't really see the point. I'm not a mechanical engineer though so maybe I'm missing something.
This point seems to come up every time there is a discussion on rotor size. I can see your rationale in the thought, but it's because braking is a function of torque arm, or "moment" if you will, not just a straight force and friction calculation.
So the further you get away from the hub (bigger rotor), the more force you are able to apply. Good analogies would be: the arm on your breaker bar, trying to push a door shut with 1 finger close to the hinge vs close the handle, or trying to stop a spinning fan blade at the hub vs at the blade tip.
If it were just a linear force calculation, all rotor surfaces could essentially be sized just big enough to accommodate your pad size (barring the whole heat dissipation thing).
Hope that makes sense.
PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
