01-19-2021, 10:40 PM
Real Name: Lynn Hobbs
Largest Battery Size for 2003 4runner V-6
Does anyone know what the largest battery is that you can fit in the stock battery tray area? My son needs a new battery and I don't want to relocate it but would like to put the biggest battery I can fit in it. Any help appreciated!!
01-19-2021, 10:57 PM
I think I've read around if it's too big the alternator can't charge it. I'm running an Optima redtop but don't remember the group number, I'd have to check the battery tomorrow.
Sent from my SM-G986U using Tapatalk
01-20-2021, 01:02 AM
Group 31 barely fits. Group 27 fits well with stock tray and mount and has almost the same capacity.
Black 2008 Sport V6 4WD | Toytec BOSS 3/2 | JBA UCA | BFG KO2 255/75/17 | Rocksteady Skids | White Knuckle Sliders | TJM Front Bumper | Superwinch
01-20-2021, 01:27 AM
If you think about it and don't mind let me know. I want to put as large of capacity battery in as I can for my son.
01-20-2021, 09:01 AM
group 31 fits, just need to extend the cables a little since the post is more in the middle.
27f fits, bigger than the 24f
24f fits
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
01-20-2021, 02:01 PM
I would focus on the quality of the battery. Look at AGM's. I love my intimidator glass mat battery.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
01-20-2021, 03:37 PM
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
01-20-2021, 03:45 PM
Sizing chart from Toyota indicates a 2003 Toyota 4Runner V6 takes the stock 24F or optional 27F.
Depending on what your battery needs are (e.g., cold weather starts, running lots of electrical equipment) it would be advisable to stick with the stock size.
https://www.toyotapartsandservice.co...teries2019.pdf
01-21-2021, 02:49 AM
My redtop is a 35 after all, says Red35 on the sticker and if you look near the positive post says 35 there also. No issues with it. Don't remember quite how long I've had it, but it's been at least three years I'd say.
01-21-2021, 04:17 AM
Real Name: Carlos V.
Same set up.
Also Optima 35 with HKB fuse/diode, but only 1 year and 10K miles. Time will tell
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
01-21-2021, 10:30 AM
i saw an install video or writeup where they say the redtops fit but the battery connections are tight. the ground is tight and the positive is stretched i remember them saying. did you notice that? they said you have to position the battery as far back and towards the edge for them to reach
if i dont just get a traditional 24 or 27 (i know toyota says 27f as option, but there are accunt of those sitting off the lip of the tray i believe) ill grab a redtop or x2 24 agm
01-21-2021, 11:59 AM
Why the diode? Just curious as I don't run one and zero problems.
It's been a while, but I don't remember the install being anything but straight forward.
01-21-2021, 01:36 PM
i think they might be referring to a diode added to trick the alternator to charge stronger or more for the AGM battery specs. otherwise the most the stock alternator can charge is less than the AGM output, by like 20%
01-21-2021, 01:57 PM
Yeah but the person I quoted is running same red top as I am. Just wondering why.
