01-25-2021, 02:24 PM
#16
Has anyone tried to install a JVC headunit using the Metra 70-8114 Steering Wheel Controls Harness and the Axxess ASWC-1 Steering Wheel Control Adapter?
This is what Crutchfield provided in my order and I cannot get the steering wheel controls to work.
01-26-2021, 06:06 AM
#17
I had an older JVC CD\DVD head unit in the 4Runner when I bought mine last year in Feb. It had the same steering controller. I was able to utilize it as well when I installed my new Pioneer AVH-2550NEX head unit.
Have you tried to program it? If not you'll need to. They have videos on the Metra website showing how. Mine was kind of a PITA but I eventually got the programming sequence correct.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
01-26-2021, 04:28 PM
#18
Anybody have any idea what the bolt/screw spacing on the factory backup camera for fourth gens is? My factory backup camera works, but the quality is pretty rough- has probably degraded a bit in its 15 years of life. I don't mind to run wiring all the way to the head unit as I'll be replacing the factory unit with a Sony at the same time. Any suggestions for something that will fit well in the factory camera location! Thanks!
01-26-2021, 04:44 PM
#19
Real Name: Ed
Real Name: Ed
Originally Posted by Tironeous
@I have a JBL with Navigation unit from an 05 limited if you’re interested.
you are including the "brain box", correct? (separate from the head unit)
01-26-2021, 05:06 PM
#20
Real Name: Ed
Real Name: Ed
If going with a newer HU, ditch the factory camera, it's low res. Because you have the factory camera, there are already holes in the tailgate to fish the wires through. I'm not entirely sure you can reuse those wires, but the camera will be have to be ditched.
I've used this camera with success (link). It it about the size of the factory camera. You MIGHT have to drill a hole in the rear tail gate trim to properly secure it though. I'm sure you can use some sort of bracket to secure it too if you don't want to drill a hole for it. Good luck
Amazon.com: NATIKA Backup/Front View Camera,IP69K Waterproof Great Night Vision HD and Super Wide Angle Metal OEM Style Reverse Rear View Backup Camera for Cars Pickup Trucks SUVs RVs Vans (Black): Car Electronics
01-26-2021, 05:40 PM
#21
Real Name: Joe
Real Name: Joe
Point me towards directions on how to remove that. Happy to look into it.
01-26-2021, 06:22 PM
#22
Real Name: Ed
Real Name: Ed
I want to say it is located where the factory amp is (the rear, passenger side cargo interior trim).
https://www.toyota-4runner.org/854236-post3.html
So yeah, without it, the OEM NAV HU is worthless (for navigational functions)
01-26-2021, 06:57 PM
#23
Real Name: Joe
Real Name: Joe
Good to know. Is it worthless for nav on 4Runners that had nav originally? Or is the headunit “paired” to the brain?
01-26-2021, 08:47 PM
#24
Real Name: Ed
Real Name: Ed
As far as I know, the radio should work without it, but any GPS functions will not work. From 2005 on, Toyota "moved the brain" into the headunit, thus the "brain box" disappearing.
01-27-2021, 12:55 PM
#25
When I previously tried installing the unit, the box would light up red for a second turn off. I vaguely remember seeing a vid saying it will blink green when programming/programmed?
01-27-2021, 02:21 PM
#26
Mine was the same way. There were a few different ways to do it. The one where it auto recognises it and sets it up itself was supposed o be the easiest. Mine I had to do it manually by selecting which brand HU and follow that method. Sounds like just a programming issue if you have it wired correctly.
01-28-2021, 12:56 AM
#27
Crutchfield is your friend my man. They have great customer service and if you are unhappy with the unit, you can return it. They also sell you all the kits to get proper fitment and keep all your steering controls working. Their customer service can also assist in selecting a good backup camera to work with the unit your purchasing.
I am currently in process of returning a unit I ended up not liking and Crutchfield was very understanding of my special circumstance in missing the 60 day deadline and approved the return.
01-28-2021, 02:48 PM
#28
Got it, just looked up how to hopefully program it. Appreciate the lead!
This is also good to know. I purchased everything through them so I guess worst turns to worst I can return/exchange it.
01-28-2021, 03:00 PM
#29
Originally Posted by blkexp98
Sorry for the lack of replies. My notifications were not coming through. For the wired Android auto and Apple car play where have you mounted your phones? I don't want to block my ac vents and the low mounts look like they block the cup holder access.
Thanks for the great info and install tips.
Sent from my SM-G975U using Tapatalk
For me the beauty of apple car play/ android auto is that you can plug your phone in and then not have to touch it again while driving. I ran a usb extension from the back of the headunit under my cupholders to a usb port in one of the empty switch ports on the center console. I just plug it in there and set my phone on the dash or in the center console because now I can use maps, calls, etc, from the headunit itself.
05 v8 Limited - Eibach Pro Lift Kit 3" Front, Ironman foam cell pro w/ 3" mid weight coils Rear - JBA High Caster UCAs - Coastal Offroad High Clearance Rear Bumper w/ Dual Swingarms - Toyo Open Country ATIII 285/70/17 - Bronze Raceline Clutch 17x9 Wheels - Raptor Liner Paint - Front Sway Bar Delete - Extended Rear Sway Bar Links - Rear Diff Breather - RCI 1/4" Aluminum Front Skid - Cali Raised DOM Rock Sliders
02-01-2021, 01:03 PM
#30
Wanted to say thanks again I was able to get it installed and all steering wheel controls work after manually programming it.
