Old 01-11-2021, 02:51 PM #1
ewokfarmer ewokfarmer is offline
ewokfarmer is on a distinguished road
Passenger Rear Turn signal quit working after light bar/ditch light install
Hello!
So I recently installed a light bar and some ditch lights on my 08 4runner. It seems like after I installed those lights, my passenger rear turn signal quit working. Bulb was fine as I tested it in the driver side socket without issue. Curious if I could have possibly cut a wire when going through the firewall with a flathead screwdriver? Fuses looked good, and I would think if it was a fuse issue more than one blinker would be out.
Anyone have any suggestions?
ewokfarmer is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 09:11 PM #2
Direwolf82 Direwolf82 is offline
Direwolf82 will become famous soon enough
Test the sockets if you can. Mine had corrosion that was causing issues at one point. Sanded and greased the tabs and no issues since. Hopefully that's more where the problem is than a cut wire.
If it was a fuse it should be controlling more than just that light.
Otherwise you need to check where you penetrated the firewall and see if you cut something. Hopefully you can access the area.
Sent from my XT1650 using Tapatalk
Direwolf82 is offline   Reply With QuoteReply With Quote
issue , light , lights , passenger , rear
Passenger side front turn signal not working dahorst 5th gen T4Rs 2 06-03-2015 06:58 PM
Turn signal/running light not working slb81 4th Gen T4Rs 1 04-02-2015 07:53 PM
Right front turn signal running light not working Tamscott 4th Gen T4Rs 6 03-30-2015 07:34 PM
