Old 01-11-2021, 03:23 PM #1
TejasRunner01 TejasRunner01 is offline
TejasRunner01 will become famous soon enough TejasRunner01 will become famous soon enough
How much does MPG drop after daystar lift on stock wheels?
Hey everyone,
As stated in the title, what kind of drop in MPG did you see when lifting using a daystar lift while retaining stock size tires?
I have a 4wd V8 getting 20.5 on the highway which is amazing. Curious to know how this would alter that.
Thanks!
Sent from my Mi MIX 2S using Tapatalk
TejasRunner01 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 03:38 PM #2
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Tire size/tread is what really kills MPG, just raising the truck a couple of inches shouldn't impact you much until you start getting up there in MPH. You are slightly decreasing your aerodynamics when lifting because you are exposing more of the undercarriage which is highly turbulent and hard for the air to pass through. I bet unless you are driving in the 75-80 MPH you won't notice much difference. If you cruise a lot at those speeds I would say expect to lose around 1 to 2 MPG worst case scenario.
702tripgen is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 08:44 PM #3
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Probably even more at speed if you level it out and or get rid of that factory rake.
Old 01-12-2021, 10:00 AM #4
PeteZ06 PeteZ06 is offline
PeteZ06 is on a distinguished road
10-15% loss
2003 T4R.. Lifted and Armored
2014 BMW 535Dx Deleted and Tuned
2020 Lexus ES350 F-Sport
2010 Harley Road Glide Exhaust and Cams
2008 Suzuki B-King Pipe/Tune 200whp
PeteZ06 is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 03:15 PM #5
bradynasty bradynasty is offline
bradynasty is on a distinguished road
What tires are you running getting 20.5mpg? I'm lucky to see 18.5 in my 04 V8.
bradynasty is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 03:45 PM #6
Bumbo's Avatar
Bumbo's Avatar
Best mileage I ever got was with the michelin defender ltx m/s, and it held its own off-road as well.
That said, 20.5 is pretty dang good. I dont think I actually got that high.
Old 01-12-2021, 04:36 PM #7
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Gas Mileage with lift
Lift affects mileage?
2" vs 3" Lift MPG
lifted v6 or lifted v8
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 02:25 AM #8
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Originally Posted by TejasRunner01 View Post
Hey everyone,
Thanks!
ZERO difference. It's acceleration and driving habits. 55mph roads do wonders to keep the MPG near 20 or above.
and also I upgraded one size to 265/70/17 and the MPG indicate correctly, though the odometer is off by 5%, which is ok, because that means it looks like my mileage will be lower.
gaber6 is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 11:54 PM #9
This is incorrect, sorry.
Old 01-18-2021, 11:17 AM #10
ieatfish's Avatar
ieatfish ieatfish is offline
ieatfish will become famous soon enough
ieatfish's Avatar
I put mine on last week. I've actually seen an increase though I'm attributing that to the alignment I got afterward. Still, I also haven't seen a hit. Still getting 18-22 depending on surface streets, freeway, and whatnot. And I'm on larger tires as well.
2006 4Runner Sport Edition 4WD V6
Dobinsons 2.5"/1.5" - C59-302, GS59-221, C59-505, GS59-705 | General Grabber ATX 265/70R17 | TPMS Bypass Mod
Custom Storage Box/Sleeping Platform Build | Dedicated Transmission Cooler (Derale D13503) | Demello Offroad Sliders
ieatfish is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 10:27 PM #11
Ok. with one size up, it's nearly ZERO. Prior to going up one size, the mpg always read too high at 20-21.. Now it is accurate at 20-21. I can hypermile by accelerating super slowly and timing lights and get 24, but that's god awful. Or I can gas it from every light and get 17.
daystar , drop , lift , mpg , stock
Need Tires for Stock Wheels and Suspension with Daystar 2.5 lift? 4RunnerRedondo 3rd gen T4Rs 5 11-21-2014 01:13 AM
rear wheels off center after lift and pan hard drop woodro 3rd gen T4Rs 10 02-13-2013 07:12 PM
Need a pic of daystar lift kit with stock tires knightsfs4 4th Gen T4Rs 8 04-04-2011 11:38 AM
Daystar, Toytec BL, 285/70/17 NTG, Spidertrax on Stock 17" Sport wheels = RUB BODYMNT grimpy 4th Gen T4Rs 10 12-08-2010 03:17 PM
Pics of my 06' Sport w/daystar lift and wheels 1FastS4 Engines / Suspension / Wheels / Tires / Audio / Accessories 6 08-29-2006 09:01 PM
