Old 03-17-2021, 06:34 PM #1
digi's Avatar
digi digi is offline
digi is on a distinguished road
digi's Avatar
Oil leak around transfer case?
Just wiped it clean but there was oil over the black bracket (with 3 holes) in the picture. Transfer case actuator?
Any ideas where to start? Checked transmission fluid which is good. This oil isn't red, its actually oil colored.
digi is offline   Reply With QuoteReply With Quote
Old 03-17-2021, 10:11 PM #2
Derekv Derekv is offline
Derekv is on a distinguished road
Transfer case actuator seal(s) are leaking. Parts are inexpensive and if you’re careful, you can do the work yourself. Several tutorials around explaining the process.
Derek V
Derekv is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 02:17 AM #3
TheV6ThatCould TheV6ThatCould is offline
TheV6ThatCould is on a distinguished road
Just to make sure, you saw it clean recently? It looks like a decent amount but is it possible that was just run off from a messy drain/fill? It sort of looks like it starts at the fill plug..
TheV6ThatCould is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 04:20 AM #4
Tomm- Tomm- is offline
Tomm- is on a distinguished road
Its a common issue on the 4th gen. It's more than likely the main "O" ring but if you're going to replace you should probably go ahead and do your actuator shaft seals as well.
The O ring is part # 90301-56009 (some people put 2 of them in there) and the seals can be bought from Colonial seal, part # "15x23x7 AS NBR"
Link to the walk thru if you do it yourself: Fixing the transfer case shift motor leak from within..
If you take it to the dealership be prepared for a $1500-$2000 bill. You could also just replace the whole transfer case actuator (comes with new o ring and seals) but that too will cost between $700-$1200 just for the part.
2004 4Runner Sport V8
ARB - AUXBeam - Bilstein - Cali Raised - Camburg - CBI Offroad - Dobinsons - Factor 55 - Fat Bob's Garage - Maxtrax - Method Racing - OME - Prinsu Design Studios - Remark - Rotopax - Smittybilt - Traveler - Yokohama
2009 Ford F-150 Platinum
2013 Scion FR-S
Tomm- is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 09:57 AM #5
UrbanRunner651's Avatar
UrbanRunner651 UrbanRunner651 is offline
Real Name: Newell
UrbanRunner651 will become famous soon enough
Real Name: Newell
You sure its actually oil..?
Oil in the X case is gear oil, different from motor oil and wouldn't likely be that dark unless it's never been touched.
Looks thick & cruddy like grease splatter from the drive shaft to me.. Nothing to be concerned over.
08 V6; Dobinsons IMS, Spidertrax, Prinsu, Revo 3s, AFE pro dry, Mishimoto catch, JBA shorties, Custom Y pipe, Borla pro XS, Hayden trans cooler, Ultragauge, Fumoto, +More..
UrbanRunner651 is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 11:15 AM #6
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
There's a lot of grease fling in the first photo.
OP, cleck and change the transfer case oil, make sure the fill and drain are sealed and tight. Then I'd clean all the muck down with some kerosene and just keep an eye on it.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 03-18-2021, 09:11 PM #7
digi's Avatar
digi's Avatar
Drained and filled last night, gonna keep an eye on it. I want to say the gear oil fluid looked good, at least a quart came out. Think it calls for 1.5 quarts. I'll report back in a few days. Greatly appreciate all the replies! Thank you
checked , fluid , ideas , oil , start
Oil Leak - transfer case?? tollboothwilley 4th Gen T4Rs 17 02-14-2022 01:39 PM
Transfer case leak GD2013 5th gen T4Rs 20 03-06-2018 04:52 PM
Transfer Case Leak Jdrum1 Classic T4Rs 1 08-21-2013 11:13 PM
Transfer case leak Laubage 5th gen T4Rs 13 11-01-2012 10:22 AM
Transfer Case Leak MJW 3rd gen T4Rs 2 08-19-2012 07:48 PM
