Old 01-13-2021, 09:26 PM #1
gloch gloch is offline
gloch is on a distinguished road
Sound upgrade: Bypass tweeters for 6x9?
I had one of my tweeters in the upper front door blow, so I thought I would simply install some nice 6x9s. It appears that the signal goes through the tweeter and then to the lower door panel speaker. Has anyone figured out the wiring to bypass the tweeters?
gloch is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 12:26 PM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous will become famous soon enough Tironeous will become famous soon enough
Tironeous's Avatar
Real Name: Joe
If I remember correctly from upgrading my speakers to components, the signal goes to the tweeters first. Then you’ll see a set of wires coming out of tweeter and back down the door to the woofer.
Try connecting from where the source enters the tweeter to the new 6x9s. You can use an adapter like this if necessary.
Metra 72-8104 Speaker Wiring Harnesses For select 1992-up Toyota-built vehicles — adapt new speakers to the factory wiring plugs at Crutchfield
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Trail Wheels (early 5th gen) | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 03:17 PM #3
JH225 JH225 is offline
JH225 is on a distinguished road
Unless you already have some coaxial 6x9 speakers, I highly recommend spending a little extra and getting a component set of speakers (6.5” with adapter, or 6x9, whatever suits your fancy).
Having the tweeter up high makes more of a difference than you may think!
JH225 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:19 PM #4
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Probably worth mentioning also that the factory "tweeter" is really a 2"ish full range driver that's high passed around 200Hz (my estimate by ear). It's not just playing high frequencies.
If you look at a frequency chart of musical instruments, you'll see that very few have fundamental frequencies above the 3,000 Hz that is the typical crossover frequency used by component systems. IOW, with true tweeters in the upper door locations, your ankles will be enjoying the majority of your musical content. Just some food for thought.
2003 Limited V8 4x4 - Galactic Gray Mica
Motorola T605 Bluetooth install
riverwolf is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 11:46 AM #5
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
I second getting components. Even an entry level set will sound better than the 15ish year old speakers in there
Old 01-16-2021, 07:02 PM #6
gaber6 gaber6 is offline
gaber6 will become famous soon enough gaber6 will become famous soon enough
Crutchfield has good deals and come with free adapters and all the wires are there too. I ordered 6.5" replacements all around recently and the previous owner had already upgraded the speakers, but the wires were just all broken or bad connections. Rears were buggered from the adapters shaking loose so I replaced those..
Keep the 6.9 up front. I actually disconnected my 8" sub behind my seat after getting everything shored up again, as it'll be just fine if you aren't an audiophile.
gaber6 is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 08:40 AM #7
Ricky Bobby 123 Ricky Bobby 123 is offline
Ricky Bobby 123 is on a distinguished road
This is what I done did. Now we really have did it.
Sound upgrade: Bypass tweeters for 6x9?-4f17fc5b-60f1-4c1c-85af-549cd9de996d-jpg
Ricky Bobby 123 is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:09 PM #8
Buggynut Buggynut is offline
Buggynut is on a distinguished road
Im replacing my sub, and was looking at the rest of the speakers. They arent very impressive for a JBL system.
Buggynut is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:17 PM #9
southern_runner southern_runner is offline
southern_runner is on a distinguished road
I'm working on this now; I have a 2003 SR5 with original factory system minus the head unit which had already been replaced. I'm going with Kenwood 6.5"s in all four doors, and Kicker tweeters because Crutchfield is damn near out of everything else.
Sound upgrade: Bypass tweeters for 6x9?-20210615_133225-jpg  Sound upgrade: Bypass tweeters for 6x9?-20210615_133216-jpg
southern_runner is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:47 PM #10
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 will become famous soon enough
If going component, there should 100% be a separate crossover to split the frequencies, then wires to speakers. By themselves, speakers definitely do not operate in a “take what frequencies it needs and sends the rest on”.
Do these speakers have built in crossovers? Component speakers should not…
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:35 PM #11
The JBL front door setup isn't like a traditional aftermarket component set. Both the 6"x9" and the 65mm drivers receive full range signals from the amp. However, the 65mm driver wiring does contain a bass blocking cap (estimated around 200Hz, to my ear). Since the guys at JBL actually know a thing or two about speaker design, although I've never measured it, I would assume that the 6"x9" was designed with a natural high frequency roll-off that complements the 65mm driver to avoid major peaking or comb filtering.
bypass , door , signal , sound , tweeters
4th gen sound upgrade carter316 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 03-30-2017 12:41 AM
No sound after speaker upgrade parawing742 4th Gen T4Rs 9 03-10-2014 11:14 AM
00' Sound system upgrade Help krmccour Engines / Suspension / Wheels / Tires / Audio / Accessories 20 02-18-2013 04:49 AM
Sound system upgrade DTaylor 3rd gen T4Rs 3 11-16-2012 01:39 PM
Sound System Upgrade rockwall 4th Gen T4Rs 3 04-22-2009 08:14 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
