Old 01-13-2021, 09:26 PM #1
gloch gloch is offline
gloch is on a distinguished road
Sound upgrade: Bypass tweeters for 6x9?
I had one of my tweeters in the upper front door blow, so I thought I would simply install some nice 6x9s. It appears that the signal goes through the tweeter and then to the lower door panel speaker. Has anyone figured out the wiring to bypass the tweeters?
gloch is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 12:26 PM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
If I remember correctly from upgrading my speakers to components, the signal goes to the tweeters first. Then you’ll see a set of wires coming out of tweeter and back down the door to the woofer.
Try connecting from where the source enters the tweeter to the new 6x9s. You can use an adapter like this if necessary.
Metra 72-8104 Speaker Wiring Harnesses For select 1992-up Toyota-built vehicles — adapt new speakers to the factory wiring plugs at Crutchfield
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 03:17 PM #3
JH225 JH225 is offline
JH225 is on a distinguished road
Unless you already have some coaxial 6x9 speakers, I highly recommend spending a little extra and getting a component set of speakers (6.5” with adapter, or 6x9, whatever suits your fancy).
Having the tweeter up high makes more of a difference than you may think!
JH225 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 04:19 PM #4
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Probably worth mentioning also that the factory "tweeter" is really a 2"ish full range driver that's high passed around 200Hz (my estimate by ear). It's not just playing high frequencies.
If you look at a frequency chart of musical instruments, you'll see that very few have fundamental frequencies above the 3,000 Hz that is the typical crossover frequency used by component systems. IOW, with true tweeters in the upper door locations, your ankles will be enjoying the majority of your musical content. Just some food for thought.
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 11:46 AM #5
Tironeous's Avatar
Real Name: Joe
Tironeous's Avatar
Real Name: Joe
I second getting components. Even an entry level set will sound better than the 15ish year old speakers in there
Old 01-16-2021, 07:02 PM #6
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Crutchfield has good deals and come with free adapters and all the wires are there too. I ordered 6.5" replacements all around recently and the previous owner had already upgraded the speakers, but the wires were just all broken or bad connections. Rears were buggered from the adapters shaking loose so I replaced those..
Keep the 6.9 up front. I actually disconnected my 8" sub behind my seat after getting everything shored up again, as it'll be just fine if you aren't an audiophile.
gaber6 is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 08:40 AM #7
Ricky Bobby 123 Ricky Bobby 123 is offline
Ricky Bobby 123 is on a distinguished road
This is what I done did. Now we really have did it.
Sound upgrade: Bypass tweeters for 6x9?-4f17fc5b-60f1-4c1c-85af-549cd9de996d-jpg
Ricky Bobby 123 is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:09 PM #8
Buggynut Buggynut is offline
Buggynut is on a distinguished road
Im replacing my sub, and was looking at the rest of the speakers. They arent very impressive for a JBL system.
Buggynut is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:17 PM #9
southern_runner southern_runner is offline
southern_runner is on a distinguished road
I'm working on this now; I have a 2003 SR5 with original factory system minus the head unit which had already been replaced. I'm going with Kenwood 6.5"s in all four doors, and Kicker tweeters because Crutchfield is damn near out of everything else.
Sound upgrade: Bypass tweeters for 6x9?-20210615_133225-jpg  Sound upgrade: Bypass tweeters for 6x9?-20210615_133216-jpg
southern_runner is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 04:47 PM #10
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
If going component, there should 100% be a separate crossover to split the frequencies, then wires to speakers. By themselves, speakers definitely do not operate in a “take what frequencies it needs and sends the rest on”.
Do these speakers have built in crossovers? Component speakers should not…
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:35 PM #11
The JBL front door setup isn't like a traditional aftermarket component set. Both the 6"x9" and the 65mm drivers receive full range signals from the amp. However, the 65mm driver wiring does contain a bass blocking cap (estimated around 200Hz, to my ear). Since the guys at JBL actually know a thing or two about speaker design, although I've never measured it, I would assume that the 6"x9" was designed with a natural high frequency roll-off that complements the 65mm driver to avoid major peaking or comb filtering.
Old 02-03-2023, 10:07 AM #12
03v8raleigh's Avatar
03v8raleigh 03v8raleigh is offline
03v8raleigh is on a distinguished road
Please help! I am trying to bypass my tweeters, and this doesn't make sense. Wouldn't you need to jump the 1st + 3rd pins, and 2nd + 4th pins? That way it is essentially red to red and back to black on the next plug to the tweeter, effectively cutting the tweeter out of the circuit and directing it down to the 6x9?
I have a new 6x9 coaxial installed, since I thought I'd just leave the tweeter, and once installed I realized the tweeter sounds like garbage and want to just remove it and have only the coaxial 6x9s going (in retrospect I should have gotten components, and mounted the new tweeter in the old tweeter spot.. but regardless I need to figure out this wiring if I'm going to do that in the future anyways). Please tell me which wires to connect together to get all power to the 6x9 lol finding conflicting info everywhere
2003 Sport Edition 4x4 V8 with 170k+. 3" spacer lift on Billsteins w/stock coils, SPC UCA's, rear Airlift bags, Flowmaster, 285/70/17 Falken Wildpeak AT3W on 17x9 Dick Cepek rims, LED Interior swap, grill-mounted light bar, Thule roof bars/bike racks with rear lights, Kenwood stereo with Sony speakers
03v8raleigh is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 11:20 AM #13
Ph03n1x24's Avatar
Ph03n1x24 Ph03n1x24 is offline
Real Name: Mark
Ph03n1x24 is on a distinguished road
Ph03n1x24's Avatar
Real Name: Mark
I recently upgraded the sound system in my 2005 4runner. I used a pair of crossovers along with metra adapters and mounting adapter plates (I had to drill to the diameter of the tweeters with a hole saw). With the metra's I did no splicing into the factory harness. (If you disconnect the tweeter the front lower door woofer will NOT function)
Kicker 46CST204 CS Series 3/4" dome tweeters
w/ crossover
Kicker 47KSC69304 KS Series 6"x9" 3-way car speakers
w/ crossover
Metra 82-4201 Tweeter Mounting Brackets
Metra 82-8148 Speaker Mounting Brackets
Install Bay SPHKC Speaker Installation Kit
As far as bypassing... a 4-pin adapter works (jumpered +/-) directing signal down to the 6 x 9's - but allowing you to reverse it back to stock.
You could probably get better advice but here's what I have done with the help of Crutchfield.
Sound upgrade: Bypass tweeters for 6x9?-w8ekvtjh-jpg  Sound upgrade: Bypass tweeters for 6x9?-wire-splicing-jpg  Sound upgrade: Bypass tweeters for 6x9?-tweeter-jpg  Sound upgrade: Bypass tweeters for 6x9?-tweeter2-jpg
2005 Toyota 4Runner Sport Edition 4.0L 6cyl 5A | 5th Gen TRD wheels w Dunlop 265/70R17 113 S Tires | CKAuto 2" Hub Centric Wheel Spacers | 3" Lift + 1" leveling kit | Pro FOX Coilover Shock Suspension Kit | Deleted Hydraulics | Retrofit LED / USB 3.0 | PC38 Pedal Commander | Alpine iLX-w650 w KTA450 | Kicker KS Series 6"x9" 3-way - CS Series 3/4" dome tweeters - KS Series 6-1/2" 2-way | Hifonics BXX1200.1D 1200W RMS 1 Ohm amp | Dual JL 10w6v2's |Q box 50hz
2011 Toyota 4Runner SR5 - Soundproofing | HU & Speaker Upgrades
Ph03n1x24 is offline   Reply With QuoteReply With Quote
Old 02-03-2023, 05:21 PM #14
TXST8SR5 TXST8SR5 is offline
TXST8SR5 is on a distinguished road
Crutchfield makes it too easy. I have done many stereos, but I still appreciate how they do things.
I ordered a JL component set for the front and JL coaxial for the rear doors for my son's 2006. Looking forward to working on it with him.
TXST8SR5 is offline   Reply With QuoteReply With Quote
bypass , door , signal , sound , tweeters
4th gen sound upgrade carter316 Engines / Suspension / Wheels / Tires / Audio / Accessories 10 03-30-2017 12:41 AM
No sound after speaker upgrade parawing742 4th Gen T4Rs 9 03-10-2014 11:14 AM
00' Sound system upgrade Help krmccour Engines / Suspension / Wheels / Tires / Audio / Accessories 20 02-18-2013 04:49 AM
Sound system upgrade DTaylor 3rd gen T4Rs 3 11-16-2012 01:39 PM
Sound System Upgrade rockwall 4th Gen T4Rs 3 04-22-2009 08:14 PM
