Old 01-25-2021, 04:40 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Holes Left By Running Boards
Does anybody do anything to the holes left by the running boards? I sold mine so there are no bolts in the holes anymore. Are they rust protected inside? Or should I put a dab of caulk in each one to protect it?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 04:47 PM #2
little_joe little_joe is offline
little_joe will become famous soon enough
I put a dab of Hylomar (any RTV would be fine) on the bolts and put them back in place. Sorry I don't remember what size the bolts are, but imho this is useful if you ever want to re-use those holes for something else.
little_joe is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 04:51 PM #3
phatcheeks's Avatar
phatcheeks phatcheeks is offline
phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough phatcheeks is a jewel in the rough
phatcheeks's Avatar
I put the bolts back in. I dont remember the thread pitch but when I removed my xreas those bolts were the same size and used some of those to plug the holes.
04 V6 4x4. Eibach Pro Truck Shocks, OME 885, Icon 2" Springs. JBA UCA. 255/75/17 Kenda Klever AT/2. Spartan rear locker(removed). PCK. Hidden Winch
phatcheeks is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 05:01 PM #4
I still have some bolts that are the same thread pitch, so I may go to Lowes and grab the shortest bolt that will fill the hole.
Just not sure if that's actually needed or not. I've got a big tube of black RTV, so I've also considered just putting a glob of that in each.
Old 01-25-2021, 05:12 PM #5
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
I just put the bolts back in mine as well. I wanted to keep them sealed and if I wanted to use them again they are ready to go and threads are clean.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 07:30 PM #6
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I put a dab of black rtv in/around the hole and reinstalled the bolts to make sure they are sealed.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 09:33 PM #7
TheV6ThatCould TheV6ThatCould is offline
TheV6ThatCould is on a distinguished road
I took the lights out of the Limited running boards (with the pre-attached wiring), drilled a hole in them, and bolted them back up where the running boards were. That way I still get some ground lighting when I lock/unlock/open doors.
Note: I replaced the original bulb with LED to get a brighter effect.
(I also replaced the original bolts back in the bolt holes that weren't being used by this make-shift lighting.)
TheV6ThatCould is offline   Reply With QuoteReply With Quote
boards , caulk , holes , left , running
FS: 5th Gen Trail Running Boards Step Boards, $250 OBO Houston, TX 4Running Man For Sale: T4R Items 8 01-28-2020 10:52 AM
Will SR5 flares cover the holes left by Limited flares? KentuckyRunner 3rd gen T4Rs 10 01-12-2016 12:41 AM
left drum brake running hot T4Rscott 3rd gen T4Rs 3 08-04-2015 02:51 AM
WTT: Sport Running Boards/Tubes for SR5/Limited Running Boards thirstyturtle 4th Gen T4Rs 9 09-14-2011 06:38 AM
I left my running boards on, got t-boned and walked away.!!!! T4RSR5'98 3rd gen T4Rs 6 02-10-2011 07:09 PM
