I ran into the same issue with my front struts. The solution was to put a small bottle jack in the position shown below, add a bit of pressure and than deal the strut hat a solid whack with a hammer. You will need a small bottle jack, as there is not much room to do this. The bolt through the bottom end of the strut allows you to use the LCA as a lever to yank down on the strut.
