Old 01-16-2021, 07:12 PM #1
BigMike18 BigMike18 is offline
Real Name: Mikey Barger
BigMike18 is on a distinguished road
Front shock stuck, bolts are all off. Help
Installing new suspension up front and the shock is the last peice but it seems to be stuck. All bolts are off and I torched, pb blasted, and pryed it (possibly in the wrong spot if you have suggestions) and came up short. I can wiggle and move the bottom as you can see the movement in the picture but the older forums I’ve read I attempted their solutions but no luck. It’s been a few years and if anyone has any new ideas or possible solutions I would greatly appreciate it. Thanks, Mike.
Front shock stuck, bolts are all off. Help-82928883-af3d-470e-918f-db58fc43a518-jpeg  Front shock stuck, bolts are all off. Help-add653bc-a164-4915-a88a-ff1474b3d840-jpeg
BigMike18 is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 07:34 PM #2
spartacus's Avatar
spartacus's Avatar
This is a first. you can try this method.
DIY: Front Strut Replacement
Old 01-16-2021, 08:08 PM #3
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Might want to try the no spring compressor method. Then you can deal with getting the shock mount off with the shock out of the way.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 10:06 PM #4
montijo505's Avatar
montijo505's Avatar
Top hat rusted to the bucket, try some more PB and a bry bar and big hammer. Frustrating but she'll come out eventually. Definitely wire brush and paint the bottom side of the bucket before putting in the new stuff. A beer or three always helps. Good luck!
Sent from my SM-G986U using Tapatalk
Old 01-16-2021, 10:24 PM #5
eleven14 eleven14 is offline
eleven14 has a spectacular aura about eleven14 has a spectacular aura about
I had the same issue on both sides, used a smaller steel wedge and BFH right at the seam where the top hat and bucket meet. Three seconds later it was free after I'd been fighting it for an hour pre-wedge.
Good luck!
eleven14 is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 12:37 AM #6
sentinel89's Avatar
sentinel89 sentinel89 is offline
sentinel89 is on a distinguished road
sentinel89's Avatar
I ran into the same issue with my front struts. The solution was to put a small bottle jack in the position shown below, add a bit of pressure and than deal the strut hat a solid whack with a hammer. You will need a small bottle jack, as there is not much room to do this. The bolt through the bottom end of the strut allows you to use the LCA as a lever to yank down on the strut.
sentinel89 is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 05:00 PM #7
Clausenfoto Clausenfoto is offline
Clausenfoto is on a distinguished road
I just dealt with this yesterday. Tried the stock jack against the UCA and fender but that just lifted the body up. Hammering a chisel or screwdriver into the top hat didn't work either. I ended up loosening the LCA bolts to get more room, and both came out after about 10 minutes of swinging the shock back in forth with my hands.
Clausenfoto is offline   Reply With QuoteReply With Quote
Old 01-17-2021, 06:35 PM #8
Well I gave your method a shot, loosen the two ball joint bolts and the front cam but then the rear one decided no. I talked nice to it with the torch and got smacked in the face for it with a broken nut. Any ideas or moving forward... fearing having to buy whole new lca, anyway I can just buy bushing and bolts and maybe clean it up a bit?
Front shock stuck, bolts are all off. Help-e0f0375d-ea83-4648-ae29-866b814e36a4-jpeg
bolts , front , shock , solutions , stuck
New Front shock top mount bolts not lining up NJ-4Runner 3rd gen T4Rs 7 08-19-2020 09:28 AM
Front Shock Nut Stuck - No Compressor Method Rockledge 4th Gen T4Rs 13 11-03-2019 09:44 PM
rag joint bolts stuck D Farms 3rd gen T4Rs 14 06-21-2016 08:59 PM
Stuck Bushing Bolts. DeclansDaddy Classic T4Rs 4 08-25-2014 07:35 PM
Stuck front differential bolts. robotmickey Classic T4Rs 13 01-09-2014 01:39 AM
