Old 12-14-2020, 08:21 PM #1
TheThreeFs TheThreeFs is offline
TheThreeFs is on a distinguished road
Lights on dashboard are flashing
Hello everyone,
So I had to replace both of my CV axles and one of my hub assemblies. The axles were really jammed in there and I had to smack the hell out of both of them to get them out. I reassembled everything and the car drives fine but now it won’t go into 4WD and cruise control doesn’t work. I’m at a loss as to what it could be. There are two lights flashing on the dash as soon as the car starts, in park, in drive, always. They don’t go off at all. ABS sensors? Front diff actuator?
Lights on dashboard are flashing-0ff0d0b9-cf80-4f66-acfa-db7a8b507585-jpeg
TheThreeFs is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 08:23 PM #2
Better pic
Lights on dashboard are flashing-950b9aba-cdff-4a6a-91cd-8ebde3009788-jpeg
Old 12-14-2020, 08:27 PM #3
montijo505's Avatar
montijo505's Avatar
Only thing I can think of electronic in that area is wheel speed sensors. One on each spindle. Might want to check the one you removed for the bearing swap.
Sent from my SM-G986U using Tapatalk
Old 12-14-2020, 08:36 PM #4
Awesome. I will check both of them. Do you think that beating on the axles to get them out could have affected the front diff actuator?
Old 12-14-2020, 10:35 PM #5
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Just curious, but you DID replace the axles one at a time, right?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 12:20 AM #6
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
Interesting. Curious why that would matter, not that I have to replace my axles yet. Also, did you get axles with/without abs or would that be part of the hub assembly?
gaber6 is offline   Reply With QuoteReply With Quote
Old 12-15-2020, 08:58 AM #7
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Abs sensors are part of the hub assembly, and if both axles are removed at the same time, you lose the timing or alignment on the differential (not sure my verbage is correct here) and it won't engage. I was instructed to do axles one side at a time unless you're replacing the differential.
Old 12-15-2020, 01:03 PM #8
montijo505's Avatar
montijo505's Avatar
I've had both axles out at the same time more than once, the last time pretty recently to gusset my spindles and control arm cam tabs. I don't see how this would cause an issue but I may have just had luck I suppose.
Old 12-15-2020, 02:45 PM #9
Yes I did. They were a real ***** to get out though. Out of curiosity what happens if you replace them one at a time.
Old 12-17-2020, 05:43 PM #10
So it turns out it’s not the ABS sensors. I’m thinking it’s the front diff actuator. I must have damaged it when replacing the CV axles. How hard is that to replace ?
Old 12-17-2020, 06:19 PM #11
montijo505's Avatar
montijo505's Avatar
I've never heard of this from a CV swap. Following to see what you figure out.
Old 12-17-2020, 06:36 PM #12
Me either. That’s why I’m perplexed. I swapped them out a few years back and the outer boots tore again so I had To do it again. This time I really had to beat the hell out of the passenger side which is The side that the actuator is on. I’m wondering what I’ll find when I get it off. I just don’t know how exactly to remove it.
Old 12-18-2020, 08:16 AM #13
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I've been looking thru my search history for a few days and I can't find the page I was reading when I was researching axles. I can't remember if I read it on here or on another site because that was around the time I did the ECGS bushing on the driver side, but it was pretty specific as far as only changing the axles out one side at a time unless you were planning to change the diff, something about losing timing on the actuator which would make the truck not engage 4wd, I can't fully remember what it said, and now I can't find it either. Probably not so much you were lucky as I may have misread something, I'll keep digging...
Old 12-18-2020, 08:21 AM #14
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I didn't see any trac or brake lights lit, so I figured it didn't have anything to do with abs. I don't believe the abs has anything to do with the engagement of the actuator. I have read about several stuck actuators, not had to change one out yet
Old 12-18-2020, 08:42 AM #15
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
For future reference, look for OEM axle-popper forks...life savers... everything else is just the hard way to do it.
Amazon.com: OEM TOOLS 27305 Axle Popper Kit, Fork & Shim Tool, Remove Most Vehicles’ Half-Shaft Drive Axles, Fix Damaged CV Joints: Automotive
axles , car , flashing , lights , loss
Tapping into dashboard lights for toggle switch lights? Dom8706 3rd gen T4Rs 15 08-25-2020 12:43 PM
Dashboard lights going out!!! Fontino New Members 2 07-25-2012 09:30 AM
Dashboard Lights theaveragejoe 4th Gen T4Rs 1 12-14-2010 02:27 PM
Various Dashboard lights flashing rustyrazor Classic T4Rs 0 08-10-2009 08:52 AM
Dashboard Lights Spokaneman 3rd gen T4Rs 1 06-19-2008 11:27 PM
