Used Eastwood internal frame coating before, I did the same as your plan - flushed the frame as thoroughly as possible with a garden hose, even took it to a carwash and got the wand into openings with the soapy setting. I could have done even more cleaning at home squirting some Dawn into the frame openings then following up with another thorough garden hose flush, then follow up with some kind of pre-paint cleaner like Eastwood offers.
I got tired of being soaking wet and stopped short of really thoroughly cleaning the frame and crossmembers internally, applying pre-paint cleaner, went to the internal frame coating and it seemed to adhere very well. Eastwood makes a good product, have at it.
Get a couple more cans and get into the radiator crossmember and the other crossmembers along the frame, spare carrier. I believe Eastwood recommends two coats, I used one coat. A smart guy, not me, would mask over some of the frame openings to prevent drippage, I believe Eastwood recommends that also.
Eye/face/head protection, gloves, long sleeves/overalls is a must. That stuff is nasty to get off when it gets on your skin. The 360 degree spray head popped out of one of the frame holes and laid a stripe of it along the side of my face.
HINT: uncoil the spray hose and lay it out straight over a house furnace duct for a day until it loses the "coil" it wants to stay in. Much easier to slide it into the various frame openings. Best of luck to you.
Will do! Thanks for the lessons learned tutorial! I'll post pics after she's welded up!!
And for external surface rust I've found Rustoleum Rust Reformer is effective, durable and cheap.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
