Old 01-21-2021, 06:00 PM #16
CarlosV CarlosV is offline
Real Name: Carlos V.
CarlosV will become famous soon enough
Originally Posted by montijo505 View Post
Why the diode? Just curious as I don't run one and zero problems.
Sent from my SM-G986U using Tapatalk
I was getting low resting volts (around 12v ) and around 13.8v while on the road so added diode to trick alt sensor and now getting higher resting and charging volts (aprox 0.5 higher volt)
Gold 2003 4Runner SR5 V6 2WD A340E
Grabber A/T, Brembo rot, Akebono pads, Optima batt, HKB Volt. booster, Buffalo Bayou recovery
Sony XAV1000, LED interior and reverse, Weathertech, Flux-Turbocharged tire valve caps.
CarlosV is offline   Reply With QuoteReply With Quote
Old 01-21-2021, 06:39 PM #17
[QUOTE=hinmo24t;3594232]i saw an install video or writeup where they say the redtops fit but the battery connections are tight. the ground is tight and the positive is stretched i remember them saying. did you notice that? they said you have to position the battery as far back and towards the edge for them to reach
It will fit w/out stretching or changing anything. Yes you have to put it far back and towards edge as seen in pics.
battery , fit , largest , put , relocate
Largest battery group that fits? jross20 3rd gen T4Rs 8 10-18-2019 08:44 AM
Trd pro largest tire size? simonsay 5th gen T4Rs 22 08-08-2015 02:05 AM
Largest Battery that can fit in the slot??? Reata 5th gen T4Rs 6 06-08-2011 11:38 PM
largest size tires on stock 15 inch rims, 99 4runner? srash 3rd gen T4Rs 5 12-16-2010 04:48 PM
largest size tires on stock 95 4Runner? jmc8387 Classic T4Rs 4 02-08-2007 08:02 PM
