Old 01-22-2021, 03:25 PM #1
gimlithepirate gimlithepirate is offline
gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough gimlithepirate is a jewel in the rough
Power Steering Hoses
Well, my power steering unit went and took my alternator with it.
Got in the car to head out to Rio Puerco today, and battery light was on. Stopped at AZ and they confirmed alternator was bad. Got home and got to looking, and found some fluid covering everything. Initially thought it was valve gasket, until I realized it was all coming from the PS pump. This was further confirmed by the fact that there was no fluid in the PS reservoir
Anyway, Rockauto recommends potentially replacing Power Steering Pressure hose and power steering return hoses when you do the pump. Anybody else do the other hoses? Or is that overkill? There are two different return hoses so replacing all the hoses would be more than the stinking pump lol.
Any recommendations on pump brands?
2007 v8 4Runner Limited Build thread: https://www.toyota-4runner.org/4th-g...ing-build.html
gimlithepirate is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 04:27 PM #2
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
My original pump (500,000 miles on it) started whining. I pulled a used one off a GX470 for $30 and threw it in. I replaced only the low pressure hose from the reservoir to the pump since it was cracking. I looked at the other hoses and decided against replacing them all due to how crazy expensive they all are.
Been driving it like this for over a month with no issues. I used OEM Toyota ATF.
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 05:09 PM #3
I'll probably grab a reman unit for the pump, but other than that I think this is the approach I'm taking. The high pressure line looked solid all told, and also looks like a pain to replace, so I'll stick with the ones that look more like they need it.
Old 01-22-2021, 07:38 PM #4
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I replaced all the low pressure return line rubber hoses using 3/8" fuel line. All the stock lines were hard as a rock. Toyota doesn't sell just those rubber lines separately but all my metal lines were good. The only Toyota hose that I used was from the reservoir to the pump, the big hose. It was also solid as a rock with just under 300k miles on it.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 01-22-2021, 11:39 PM #5
hankd's Avatar
hankd hankd is offline
Real Name: Harry
hankd is on a distinguished road
hankd's Avatar
Real Name: Harry
recently had a new rack put in and saw the same warning on rockauto. picked up a high pressure hose (got the cheapest one) and lucky i did - the original high pressure hose was seized on the rack. when i had the pump replaced last year i didn't need to replace any of the hoses. i'll try and proactively replace related parts of they are cheap enough when i'm getting work done.
hankd is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 10:25 AM #6
Why'd you get that one from Toyota? NAPA not sell that size? Or did you think the bend was important?
Old 01-23-2021, 11:28 AM #7
xtremewlr's Avatar
Real Name: Todd
xtremewlr's Avatar
Real Name: Todd
The bends that are molded into the hose. It's also kind of an odd size.
The return lines don't have the same issue. 3/8" hose is a hair big but it works. Just make sure the hose clamps are tight.
Replacing all the PS hose would also be a good time to add a new, larger trans cooler and make the old, smaller OEM trans cooler into the PS cooler like I did. Also a good time to install inline filters for both.
I use these (although I still haven't installed the ones I have onto the 4Runner): Amazon.com: Magnefine 3/8" Magnetic Inline Transmission/Power Steering Filter: Automotive
Old 01-23-2021, 11:58 AM #8
just an FYI on the fluid... toyota ATF is either T-IV or WS, not the recommended dex3 for power steering. im sure it will work ok since its just hydraulic fluid, but toyota ATF is not what the P/S calls for.
Old 01-25-2021, 02:35 PM #9
Toyota Manual says ATF Dex II or III.
confirmed , hoses , power , pump , steering
Power steering hoses cracked fbksurferjoe 5th gen T4Rs 0 04-12-2020 09:16 PM
Power Steering - cap says Dexron ATF, dealer tech says power steering fluid acolsen Maintenance/Detailing 7 02-24-2017 03:00 PM
Power Steering Pressure Hoses? beardman 4th Gen T4Rs 8 05-26-2016 11:42 AM
Cleaning Power Steering Screen + Cardone Magna-Pure Inline Power Steering Filters BamaDrewski 3rd gen T4Rs 1 03-23-2016 05:48 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
