Old 01-23-2021, 09:19 AM #1
Seasparrow Seasparrow is offline
Seasparrow will become famous soon enough
Mounting a simple removable shallow rear cargo box ?
Good Morning everyone,
I am tired of the clinking and clanking when I turn corners and finally have the last woodworking project nearly complete. I would like to add a box to the runner to hold all that noisy stuff.
The box will be short enough to go under the upper cargo deck and be removable.
My question is what is the best method of securing this thing if I want it removable. Anyone else built such a thing ??
Thanks
NATO Seasparrow Mk 57 Mod 2 & 3
2004 4th Gen Sport Edition
Seasparrow is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 12:51 PM #2
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Pull back the carpet or mat and there are tie down points. Most guys with drawer systems use these to attach the drawers to the floor.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 01:51 PM #3
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Yup, there are tie downs back there (near the liftgate on the sides, and up front near the seats) that you can use to strap down stuff.
I ended up pulling out the double-deck system entirely to put in a new 'floor' with a pull out table and a drawer system that is strapped in with turnbuckles to these mount points.
While I set this up so I can take the drawers in and out, I nearly never do, it's just too convenient having them back there since this is our main adventure vehicle. Heck, even the fridge gets used for grocery trip runs.
You can see where the mount locations are here, I reused the tie downs and just got longer bolts.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 02:47 PM #4
So I am trying to put this under the cargo deck, are you saying the carpet has to come up and there are tie downs underneath ?? Remove the carpet like your trying to replace the subwoofer, plastic side pieces and all ?
Thanks for the replies so far.
Old 01-23-2021, 02:54 PM #5
Yes, all 4runners have the mounting locations there.
Old 01-23-2021, 02:59 PM #6
Thank you very much for helping that answers the question.
Old 01-24-2021, 11:11 PM #7
yourfriendcasey's Avatar
yourfriendcasey yourfriendcasey is offline
yourfriendcasey is on a distinguished road
Are you referring to the flip up cargo shelf thingy? I have been thinking of making some kind of drawers that integrate with that but i think you made the right move just removing it. Any idea of the net weight gaun with these drawers? Those look awesome, love the slide out tables.
05 v8 Limited - Eibach Pro Lift Kit 3" Front, Ironman foam cell pro w/ 3" mid weight coils Rear - JBA High Caster UCAs - Coastal Offroad High Clearance Rear Bumper w/ Dual Swingarms - Toyo Open Country ATIII 285/70/17 - Bronze Raceline Clutch 17x9 Wheels - Raptor Liner Paint - Front Sway Bar Delete - Extended Rear Sway Bar Links - Rear Diff Breather - RCI 1/4" Aluminum Front Skid - Cali Raised DOM Rock Sliders
yourfriendcasey is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 02:20 AM #8
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
@yourfriendcasey
I built a set of 2 drawers similar to those pictures w/o the under-mount table and fridge but with sleeping platforms. My whole setup weighs in at 150 lbs.
When made from 1/2" Baltic birch for the Drawers and Carcass with one section of 3/4 for the middle divider. 1/3rd of the weight is the lockin/lock out slides.
Ways to shed weight on my setup while still using woodworking techniques:
  • 3/8" ply all around. 1/4" Drawer bottoms
  • Cutout sections of the bottom beneath the drawers
  • Cutout sections from sides by the wheelwells
  • Replace plywood drawers with custom 3 ply Coroplast with metal reinforced top mounted drawers slide
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 09:32 AM #9
Yup, the double-decker cargo shelf. Took it out. It's right around 1.5" of space, which worked out well to do the 3/4" platform, and then the pull-out table is 1/2" with some ptfe tape on the sides and under the platform to make it slide in and out nicely...
Thanks! The slide-out table was a 'light-bulb' moment when I was thinking about what to do back there and so glad I did that....we use it just about every trip out, even if its just a day trip.
box , cargo , deck , removable , thing
MudPie's Removable Rear Cargo Storage Setup MudPie 5th gen T4Rs 22 08-15-2021 11:35 PM
Removable aftermarket CARGO TRAY/SLIDER *Group Buy* 2015 jicko Group Buys 75 10-29-2020 02:24 PM
Rear bumper with removable swing outs. KEØHZA 5th gen T4Rs 7 05-15-2020 09:31 AM
Removable aftermarket CARGO TRAY/SLIDER *Group Buy* 2015 jicko Lexus GX470/460 0 04-13-2015 11:26 AM
rear bumper step trim removable? riverwolf 4th Gen T4Rs 7 06-02-2010 01:40 AM
