Old 01-23-2021, 05:35 PM #1
Forum148 Forum148 is offline
Forum148 is on a distinguished road
Tundra rear shocks or "superflexy" set up
Hey Guys,
Went down the rabbit whole today on trying to figure out how to get more travel out of the rear of our trucks without going with a full long travel kit. I think I have found that you can just run Tundra rear shocks as replacements. Wondering if anyone has first hand experience doing so.
Along my studies I also ran into the FJ guys doing what they call "superflexy" set ups. They are not using direct Tundra shocks but different shocks that extend the overall length and travel of the shock in the rear. The Tundra shock is not as long as what they are doing so I am thinking it may work fairly easily.
Here's a link to the "Superflexy" thread:
superflexy on the cheap, or more expensive if you're into that :bigthumb: | Toyota FJ Cruiser Forum
My idea here is using a 11 inch or sub 11 inch travel shock. I'm Currently running Icon 2.0's w/ icon 2" spring so I was looking at the Tundra 2.0 Icon Shock or they also make a universal 11 inch shock that could be a viable option as well. Trying to figure out if I would need to switch my icon spring for the toytec one. Gears are turning any experience or advice is much appreciated
Cheers!
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 06:28 PM #2
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Originally Posted by Forum148 View Post
Hey Guys,
Cheers!
Good question. I assume the intent is to have better traction and stability on higher-rated, slow-going CO mountain trails?
Looks like an involved process. The Icon 2.0 has just under 9" of exposed shaft and is good up to 3" lift with overall length, hand measured, 24" and per published numbers, 24.5". Other shocks good to 3" have the same extended length around 24-24.5.
So you want 2" extra. But that means how much rear lift? 4" rear lift? What would be the minimum spring that can use +2" shock travel? I don't know. But any difficulties reworking the rear suspension for a 4-5" lift aside, what front lift are you going to have to match a 4-5" rear lift?
Even at 3" of total lift front and back you are robbing your front suspension from travel in order to give your rear suspension more travel. Yet our trucks flex better in the rear anyway.
Wouldn't the end result be a truck more capable to climb big rocks and ledges but not more capable (in fact, less capable) of coming back down said rocks and ledges? Would that not cause issues, like, in rolling it on an offcamber spot that was ok going up but is not ok coming down?
Just thinking aloud.
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 01-23-2021, 06:55 PM #3
So the idea here is not actually adding lift to the truck but having a shock that has more travel which in turn will allow for more droop. The weight of the truck will have the shock sitting further into its travel but when going through rocky terrain will allow for that shock to extend to a longer length thus giving me more droop. If I need to change the spring it would be to a Toytec Superflex spring which last time I checked (and its been years since i've looked into that spring) is still good for roughly 2 inches of travel.
If you look into the FJ thread I am looking at doing his "on the cheap" set up minus using the Procomp shocks that he does.
Basically needing a spring that can support having a 10.5-11 inch travel shock. While not adding additional lift to it.
Thanks for the input I too am just thinking out loud
Old 01-23-2021, 07:11 PM #4
MAST4R's Avatar
MAST4R's Avatar
Yeah, it is fun to discuss this.
Assuming there is a spring that can do something along those lines, I guess the other question would be about the shock body vs the shock shaft.
The Dobinsons long travel allows for 3.5" in the rear GS 59-575, IMS 59-50575, and MRA A575.
So all these are 28.75" extended and 16.73 collapsed.
That sounds like what you want. May be PM Mike to see what springs work with those?
Old 01-24-2021, 09:19 PM #5
Ahhhh man but that’s too easy!
Old 01-25-2021, 03:44 PM #6
flipflopnfly's Avatar
flipflopnfly flipflopnfly is offline
flipflopnfly is on a distinguished road
If you want to go super flexy you'll have to remove the rear sway bar, then you will have to install extended brake lines. Then, if you want to sustain highway handling you will need the HD springs or airbags to compensate for removing the rear swaybar. When you lift you will need the taller 9" airbags if you go that route. It's a good setup but you have to do it right.
Donated to SoulDog Rescue - '07 Limited 4.7 4WD | Toytec Boss kit front and rear set to 2.0" in front with standard Superflex 2" lift rear coils | Firestone 9" airbags | 600W Samlex PSW inverter | Slyfox SAIP bypass | Toytec 14" rear brakelines
'08 Limited 4.7 4WD | Toytec BOSS kit front and rear set to 2.75" front standard Superflex 2" lift rear coils | SPC balljoint UCA's | Firestone 9" airbags | Slyfox SAIP bypass | Toytec 14" rear brakelines
flipflopnfly is offline   Reply With QuoteReply With Quote
icon , rear , shock , shocks , tundra
Fox Tundra 2.5" Rear Shocks w/ KDSS baysta 5th gen T4Rs 3 08-12-2020 09:15 PM
FS: 2016 "take offs" Coilovers and rear shocks, $40, St Louis MO brenfoley For Sale: T4R Items 0 02-10-2020 01:00 PM
Fs Tundra Trd spring and shocks yy-yb "SoCal" Killer6eans For Sale: T4R Items 0 03-23-2016 12:22 AM
Removing the "vulcanized" bushings from the rear Tundra Bilstein 5100s? jaredawoodruff 3rd gen T4Rs 4 11-06-2012 03:07 AM
